Serious lag...
Old Aug 7, 2024 | 12:08 PM
I was referring to the gas pedal part; lag then let off then all is good.
The instructions that come with the GMTU show how to rotate the sensor but, that requires a GM technician to look at directions. LOL (Lot's Of Luck)
Old Aug 7, 2024 | 01:28 PM
PulpFriction's Avatar
The current thinking is to always use pigtails to install the MAPs, but the dealer may not have gotten the memo, and crimped per directions. Apparently, tiny changes in resistance as those connections age cause trouble. The fix is to make new connections, and solder, grease, and shrink tube.
Old Aug 7, 2024 | 02:09 PM
There are plug and play adapters. Probably what was used.
Old Aug 7, 2024 | 02:28 PM
Since it is a relatively new installation (6 months) do you think corrosion caused by age would be a cause? The lowet MAP sensor is a problem if the installer didn't bother to read the instructions about rotating the connector out of harms way. It involves removing the registration tab with a knife or file.
Old Aug 7, 2024 | 02:34 PM
Actually Don, if the tab is removed and the Tmap sensor installed, the wire plugin will point directly to the compressor.
There is no mention of turning the sensor in the original GMTU instructions.
Turning it may have been mentioned in a later TSB.
Old Aug 10, 2024 | 11:38 AM
A few years ago I posted the directions. Don't feel like looking for it. If the tab is not there you can turn it to any position.
Old Aug 10, 2024 | 12:44 PM
There is a tab on the sensor itself that must be trimmed off in order to install it and have it seal.
Then there is a bar on the lower charge pipe that prevents the sensor from rotating. If you don't trim this, you can rotate 180 degrees. I trimmed that also to rotate it slightly, about 45 degrees. It's all in the how-to that I linked to above.
It may be that the sensor wasn't trimmed, and so it isn't sealing.
Old Aug 13, 2024 | 10:24 AM
Maybe we should consider that it was not a GM dealer that installed the kit am=nd maybe whoever did did not replace the Tmap or even did the firmware upgrade correctly. The last discussion about the GMTU I remember is that A.) GM does not sell it anymore and B.) they would not install a third party item.
Old Aug 14, 2024 | 05:35 AM
Nazgul 9's Avatar
Actually it was a Chevy dealership that did the install for me and i will be taking it back today and showing them all the info you guys have given me/// Thank you so very much for that!!!
Old Aug 14, 2024 | 06:55 AM
Possible the lower map sensor was not installed correctly. But…
What octane fuel have you been using? (As you know, 91 or better is mandatory with the GMTU.) Before taking it back, I would try some racing fuel and see if it still does it.
Possible that due to a more aggressive spark advance, an accumulation of carbon deposits is causing a knock. When that happens, knock sensor signal tells the ECM to roll back the timing.
I have a GM car (not turbo) for which 91 is “recommended.” If I feed it 87, I get the hesitation similar to what you describe. With 93, no problem.
