Synthetic Oil
Old Jan 11, 2011 | 01:12 PM
BlackknighT's Avatar
Welcome datedd & enjoy the ride!
Old Jan 11, 2011 | 09:53 PM
chudlychudson's Avatar
Requires GM4718M spec oil.
High Performance Engine Oil Specifications
Old Jan 11, 2011 | 10:08 PM
Doctor Who's Avatar
I have been a user of synthetic oil long before I got my HHR SS. But when it comes to my SS I use Amsoil Signature Series 0-30 Full synthetic. I used to put it in my GTO too.
This is from their website - so I knew it would meet GM's spec requirements.
AMSOIL Signature Series 0W-30 Synthetic Motor Oil is recommended for use in gasoline engines, diesel engines (API CF, ACEA B5) and other applications requiring SAE 0W-30, 5W-30 or 10W-30 with the following worldwide specifications:
• API SM/CF, SL, SJ …
• ILSAC GF-4, 3 …
• ACEA A5/B5-04
• GM 4718M, 6094M
• Ford WSS-M2C929-A
• Honda HTO-06
• Daimler Chrysler MS-6395N
• VW 503.00
No matter what synthetic oil you use it needs to meet or exceed GM 4718M. If you have an engine problem down the road, GM may not do the warranty work if you didn't use oil that meets their standards.
Old Jan 11, 2011 | 10:13 PM
THE BATMAN's Avatar
I'm running the Castrol Edge train these days.
Old Jan 12, 2011 | 12:00 AM
m1 5-30
Old Jan 12, 2011 | 07:31 AM
bartSS's Avatar
Originally Posted by sleeper
m1 5-30
X2 since day 1
Old Jan 12, 2011 | 12:06 PM
Sunflowerhippi's Avatar
Originally Posted by JRGHHRSS08
How long does this last for? my dealer is yelling at me for going 7k on it.
Tell them to shut up, and read your manual. Personally I would just highlight where it says to use the DIC for however long on your oil change and shove it in there face, but I am a bit angry at my local dealership right now. I am almost 10k on this oil and still have almots 30% left on the DIC.
Old Jan 12, 2011 | 04:59 PM
Rod Run's Avatar
I use synthetic in anything with a roller engine. flat tappet engines get the good ol' dino crude
Old Jan 13, 2011 | 11:12 AM
urbexHHR's Avatar
In my automotive classes we're learning that if you drive under heavy conditions (short trips, towing, police, taxi) to change every 3k miles. If you just drive regularly, then 7k. This is straight out of the book, which says it's recommended from the manufacturers.
Old Jan 13, 2011 | 12:04 PM
datedd's Avatar
Thanks folks. What about fuel? Premium or is regular OK?
