What is the Front rotor size for a non Brembo Rotor?
Old Feb 15, 2011 | 06:25 PM
DMarotta's Avatar
Simple question. What Size are the FRONT ROTORS on a 2008 HHR SS without the Brembo package?
I am trying to give my money to TurboTech because they are a supporting vendor. I want to get a quote from them for pricing and availability on the following types of FRONT ONLY rotors and pads for a stock 2008 HHR SS (NON BREMBO) so I can decide which ones I want to buy.
I understand I can mix and match rotors and pads, ie, redstuff pads with blackdash rotors or greenstuff pads with 3GD rotors and vice versa.
1. EBC 3GD SPORT BRAKE ROTORS, DIMPLED AND SLOTTED, VENTED, BLACK ZINC
2. EBC ULTIMAX BLACKDASH BRAKE ROTORS, SLOTTED, VENTED, BLACK ZINC
3.. EBC REDSTUFF LOW DUST SUPERSTREET BRAKE PADS, 2-CALIPER SET
4.. EBC GREENSTUFF 2000 SERIES SPORT BRAKE PADS, 2-CALIPER SET
The problem is TurboTech racing does not know what size the rotors are on the SS without the Brembos. So can someone help a brother out and give me the diameter of the front rotors of a 2008 HHR SS without the Brembo Package (am I being clear?)
Old Feb 15, 2011 | 06:32 PM
Sounds like you know more than I already, surprised Aaron doesn't know, it looks like this
Old Feb 15, 2011 | 07:20 PM
I believe the non-Brembo rotor is the same as the standard HHR...... Now, don't ask me what size that is, but somebody has to know.
Old Feb 15, 2011 | 07:24 PM
Sunflowerhippi's Avatar
Okay, from what I read before the SS is not the same as the base for the front. I think I read this in the manual because the spare will not fit the front over the brakes on the SS.
Sorry but I don't know the messurement.
Old Feb 15, 2011 | 08:06 PM
2010SilverIceSS's Avatar
DISC BRAKE COMPONENT SPECIFICATIONS
Front Brakes J41/JM4
 Brake Pad Lining Minimum Thickness 1.0 mm 0.039 in
 Brake Rotor Diameter 275.00 mm 10.827 in
 Brake Rotor Discard Thickness* 22.8 mm 0.898 in
Front Brakes JL9
 Brake Rotor Diameter 296.00 mm 11.653 in
Not sure if this is what your looking for but it was what I found in the service manual
Dave
Old Feb 15, 2011 | 09:58 PM
DMarotta's Avatar
Is this from your 2010 service manual or a 2008 service manual. According to Aaron at TurboTech there are 3 different sizes/part #s for the front rotor available. Per Aaron:
GD7375
Rotor; EBC 3GD Series Sport Slotted Rotors; Set of Two; Front; 10.9 in. Dia.;
GD7265
Rotor; EBC 3GD Series Sport Slotted Rotors; Set of Two; Front; 11.7 in. Dia.;
GD7507
Rotor; EBC 3GD Series Sport Slotted Rotors; Set of Two; Front; 12.4 in. Dia.;
The goal here is to simply replace the rotor and pad with the same size as was the OEM part. Short of pulling the wheel and measuring myself I am reaching out to the community.
Old Feb 15, 2011 | 10:13 PM
Mrs. DLVRNIT's Avatar
So don't qoute us on this but we would think the above information would cross reference as follows:
1) Standard HHR; LS, 1LT and 2LT
2) Standard SS HHR; non Brembo
3) Standard SS HHR; w / Brembo
Just-a-Thought / Best-O-Luck ,
Old Feb 16, 2011 | 07:45 AM
rallycobalt06's Avatar
the HHR SS without the Brembo package..... has the SAME brake setup as the 05-07 Cobalt SS/SC.
Old Feb 16, 2011 | 08:22 AM
solman98's Avatar
Originally Posted by greybeard999
i believe the non-brembo rotor is the same as the standard hhr...... Now, don't ask me what size that is, but somebody has to know.
ditto
Old Dec 2, 2014 | 10:24 PM
OkieBikerDude's Avatar
GD7375
GD7265
GD7507
Based on what I've confirmed about my '10 SS non-Brembo, this information is correct.
OBD
bdlabaere27
7
Jan 26, 2013 11:40 PM
bassbase
Oct 29, 2011 10:56 AM
txbass06
Oct 18, 2009 05:01 PM
AJochum
Sep 30, 2008 10:00 PM
