15" tires?
I have a like- New set of 215/65R15 Blizzak tires that I would like to use this winter on an HHR. Possible?
If you could find wheels that are 15 inch with a 42cm offset and a 110X5 bolt pattern. Have to be all 4.
You would have to check if the rims will fit over the disc brakes, I doubt it maybe. |
Yeah, my hope was that someone out there had tried it and could give me a recommendation as to wheels. The Blizzaks were on my previous Honda and are unbelievable in the snow. Only 3k miles on a $500 set of tires and I am hoping I can use them.
Originally Posted by donbrew
(Post 848037)
You would have to check if the rims will fit over the disc brakes, I doubt it maybe. I know you meant 42mm. :D |
didn't type "inch" anyway.
The Malibu Max came with 15 inch rims , 5 x 110mm bolt pattern and our size disc brakes up front. I think it was 2005 model year
Originally Posted by oldblue
(Post 848070)
the malibu max came with 15 inch rims , 5 x 110mm bolt pattern and our size disc brakes up front. I think it was 2005 model year
But could be wrong. |
According to our friends at RockAuto, both bolt patterns were on the Malibu, so did deep at your local pick a part or order up four new steelies with the 110mm bolt pattern
https://cimg9.ibsrv.net/gimg/www.che...ea13930b60.png |
I'm going to try
using a set of spacer/adapters, 5X110 to 5X114.3, 3/4" thick, and see if I can use my older 15" Honda CR-V wheels and Blizzaks. I';ll give you all a report, either way. Adapters will be here Wednesday.
