15" tires?
Old Jul 15, 2018 | 05:53 PM
OldSwede's Avatar
15" tires?
I have a like- New set of 215/65R15 Blizzak tires that I would like to use this winter on an HHR. Possible?
Old Jul 15, 2018 | 05:59 PM
If you could find wheels that are 15 inch with a 42cm offset and a 110X5 bolt pattern. Have to be all 4.
You would have to check if the rims will fit over the disc brakes, I doubt it maybe.
Old Jul 15, 2018 | 06:11 PM
OldSwede's Avatar
Yeah, my hope was that someone out there had tried it and could give me a recommendation as to wheels. The Blizzaks were on my previous Honda and are unbelievable in the snow. Only 3k miles on a $500 set of tires and I am hoping I can use them.
Old Jul 15, 2018 | 06:14 PM
Wow, that's gonna look like some kind of monster truck or something.
I know you meant 42mm.
Old Jul 15, 2018 | 06:33 PM
didn't type "inch" anyway.
Old Jul 16, 2018 | 07:39 AM
The Malibu Max came with 15 inch rims , 5 x 110mm bolt pattern and our size disc brakes up front. I think it was 2005 model year
Old Jul 16, 2018 | 03:02 PM
Cat Man HHR's Avatar
Originally Posted by oldblue
the malibu max came with 15 inch rims , 5 x 110mm bolt pattern and our size disc brakes up front. I think it was 2005 model year
2004-07
But could be wrong.
Old Jul 16, 2018 | 04:33 PM
According to our friends at RockAuto, both bolt patterns were on the Malibu, so did deep at your local pick a part or order up four new steelies with the 110mm bolt pattern
Old Jul 29, 2018 | 02:05 PM
OldSwede's Avatar
I'm going to try
using a set of spacer/adapters, 5X110 to 5X114.3, 3/4" thick, and see if I can use my older 15" Honda CR-V wheels and Blizzaks. I';ll give you all a report, either way. Adapters will be here Wednesday.
Marzipan
Dec 19, 2008 10:18 PM
misterjensen
Aug 21, 2007 11:12 AM
da_loca
Dec 8, 2006 12:34 AM
Lee In Calfi
Jul 19, 2006 07:22 AM
