Hi I have a 2010 chevy hhr I'm not sure which model it is it's not a panel and it's not as but I bought 5x110 to 5x114.3 wheel spacers to put on a set of rims I have they bolt right on to the 5x114.3 rims but not to the hhr so then I grabbed one the wheels and it fits the hhr so my thing is I thought they were all 5x110 but mines not I think it was some kind of fleet car it's all white and has a spot on the roof where they would of had one of those flashing orange lights any input would be greatly appreciated
Welcome
All HHR's came from the factory with 5x110 hubs. I doubt that someone has changed all the hubs to a different size. More likely that your adapter is the wrong size. Simply way to find out what you have is to just measure.
(Don't know your model. Should be an emblem on the rear hatch: LS,LT or SS. Or look at the RPO sticker in the glove box. It will designate the model)
I just put a set of 5x114.3 rims on the car yesterday with out the adapters they are dodge stratus rt rims took them off the dodge stratus rt myself and test fit it yesterday I cant find an answer to this I dont wanna hear about wrong spacers they are not wrong I kno for 100 percent fact the are 5x110 to 5x114.3 adapters so if some1 can explain this nice if not I'll waste my time in a different forum
The Dodge Stratus R/T from 1995 through to 2006 had a 5 X 100 mm bolt pattern, depending on the size of the lug holes this could explain how they fit onto the HHR 5 X 110 mm studs.
I don’t recommend running them at all.
I've also had the same wheels on a 5x114.3 honda crv I kno for fact the lug pattern is that now if theres an answer to why that would be great I'm not asking for an option on what lug pattern it
also theres no emblem on the back hatch just says ecotec I told u it was some type of fleet car it has to have some kind of different option from factory I'd measure it to show u the proof but I dont have a tape measure on hand
For that I have no answer, I can confirm that all models and years of HHR’s came with the 5 X 110 mm bolt pattern.
as for the other rims, no idea what they are off, nor what they fit.
Right on Donbrew - seems everyone is wasting their time. Shame on you FiremanGeorge for pointing out how to measure Bolt patterns, and the same for Oldblue - doing a bit of research on the Stratus bolt pattern and coming up with a possible explanation and a cautionary note - shame shame on you!!
Well Jakeallen, yeah if you believe it is a fleet car and has some kind of different option from the factory, then go with that. We've told you what hubs the HHRs came with, but you say your HHR is "special" as it has what are non-standard hubs. We have offered up some possible explanations for it, but they don't seem to help you, so perhaps you might want to find another forum where you can as you say, waste your time.
