245/45-17 or 225/50-17?
Old Sep 23, 2010 | 12:44 PM
Tony_SS's Avatar
Former Sponsor
I would love to see pics of both tire sizes, if anyone is running them!
I am going with a 17x7 wheel. What is the ideal offset?
Thank you for the help!
Old Sep 24, 2010 | 10:43 AM
Tony_SS's Avatar
Former Sponsor
So I've decided to try a 17x7.5 wheel with a 245/45-17.
If anyone has any feedback I'd love to hear it - thank you!
Old Sep 25, 2010 | 07:20 AM
ace120's Avatar
Not sure why you would need that much tire with 170 hp. You are probably just waisting gas. wider tire = worse gas milage.
Old Sep 25, 2010 | 07:33 AM
Randy_W's Avatar
Sometimes it ain't what we need, it's what we want.
Old Sep 25, 2010 | 08:25 PM
frank6060's Avatar
I hear what your saying..but I think those 245s may be to far out of your wheel well. Your splash guards/running boards may not be able to protect body panels from road debris. Turning radius may also be a problem. I run 225s, wide stance with no issues.
Old Sep 27, 2010 | 07:43 AM
Tony_SS's Avatar
Former Sponsor
I'm not sure I heard that before.. wider tires = worse gas mileage?
I might just play it safe with the 225s. But I know it would handle better with 245s. And we have some windy roads so wider is always welcome around here.
Old Sep 27, 2010 | 12:06 PM
Randy_W's Avatar
Well, all other things being equal, wider tires will create more aero drag as well as static drag due to a larger contact patch. Taller tires also create a larger contact patch by making a longer contact area. However, to a point taller tires can ease rolling resistance and balance out the equation as long as overall drive ratio isn't hammered severely and too much extra unsprung weight isn't added.
