Chevy HHR Network
-   Tires & Wheels (https://www.chevyhhr.net/forums/tires-wheels-49/)
-   -   245 45 r17 tires /rims 17" 5x5 (https://www.chevyhhr.net/forums/tires-wheels-49/245-45-r17-tires-rims-17-5x5-56809/)
sb1993 Apr 21, 2016 11:18 AM
I have a 06 hhr and wanted to know if 17" rims 5x5 would fit with tire sizes 245 45 r17?
donbrew Apr 21, 2016 11:34 AM
1 Attachment(s)
I have not checked the "tire rim calculator" located in the TOOLS menu on the menu bar or the one posted previously in this thread. But, I don't think so. Mainly because the width, the stock wheel is 6.5 if you go 5.0 a 245X45 is too wide.
Oldblue Apr 21, 2016 01:28 PM
Welcome to the site, your rims would be 17 X 6.5 with a 5 X 110 mm bolt circle.
There is a tire rim calculator in the tool bar click on tools
I moved this to it's on thread from the dead 5 year old thread
jeff schaffer Sep 2, 2016 04:49 AM
225 /45/ 17 fits im running that setup
solman98 Sep 2, 2016 10:51 AM
A 5x5 bolt pattern will not fit the HHR. HHR is a 5x110.
Depending on the offset of the wheel your putting on, a 245 will fit. I was running 245/40R18's on Cobalt SS wheels and had plenty of clearance. You 245/24R17 is 25.7" and that will clear the strut plate. The offset will determine is the width will work.
Frenchy42 Sep 3, 2016 09:27 PM
Those Cobalt wheels you're running are probably either 7" or 7.5". 245 is about the most you can shoe horn onto those. His 6.5"s though, I don't know if you can even squeeze a 235 on there.
Steve Gilbert Sep 4, 2016 05:22 AM
Will a 255 40 18 fit on front of hhr ss
