5x115 for 2009 HHR
I'm out running around trying to find new wheels for my 09 HHR. Would a 5x115 work or does it absolutely have to be 5x110? Any help/advice is much appreciated!
Welcome to the site!
Yes only 5 X 110 mm bolt pattern will fit!! |
Would a 15 mm wrench fit a 13 mm bolt? You might be able to find an adapter, but that can be dangerous.
The 5 is the number of bolts, the 110 is the diameter of the bolt circle. |
Thank you!
Also the hub bore is 65.1 mm, or for wheels with larger bore get hub centric rings to fit 65.1 mm.
