5x115 for 2009 HHR
Old May 22, 2016 | 10:08 AM
kelshwa's Avatar
5x115 for 2009 HHR
I'm out running around trying to find new wheels for my 09 HHR. Would a 5x115 work or does it absolutely have to be 5x110? Any help/advice is much appreciated!
Old May 22, 2016 | 10:12 AM
Welcome to the site!
Yes only 5 X 110 mm bolt pattern will fit!!
Old May 22, 2016 | 10:14 AM
Would a 15 mm wrench fit a 13 mm bolt? You might be able to find an adapter, but that can be dangerous.
The 5 is the number of bolts, the 110 is the diameter of the bolt circle.
kelshwa's Avatar
Thank you!
Old May 23, 2016 | 09:04 PM
prod's Avatar
Also the hub bore is 65.1 mm, or for wheels with larger bore get hub centric rings to fit 65.1 mm.
Schreiner.Photo
Sep 2, 2010 06:44 PM
lilchop
Tires & Wheels
Jul 22, 2009 08:46 PM
GDZHHR
Dec 7, 2008 05:23 PM
MikeX
Jun 14, 2006 04:46 PM
