Another rim question will it fit???
Old Mar 2, 2010 | 04:21 PM
Hillbilly Hot Rod's Avatar
OK, I hate to bother all you good folks again with another rim question, but they are very expensive and I just want to make sure what I get will fit. plus the rims I wanted are not carried anymore. here it goes,
will this fit my HHR?
17 X 7.50
offset 35
Thanks for all your help.
Old Mar 2, 2010 | 05:42 PM
fringeIT's Avatar
Is the bolt circle 5X110?
Old Mar 2, 2010 | 06:39 PM
Yes the bolt pattern is 5X110
Old Mar 2, 2010 | 08:41 PM
fringeIT's Avatar
The only other thing to find out is if you would need shims or not. Check this thread out:
https://www.chevyhhr.net/forums/show...t=28362&page=3
Old Mar 3, 2010 | 05:09 AM
Thanks, this offset is very confusing. time to search the net to see if I can understand offset better.
Old Mar 3, 2010 | 05:18 AM
OK, that didn't take to long, this is what I found,
http://www.1010tires.com/WheelOffsetCalculator.asp
and it is telling me there is only 1 mm less of a difference so I believe I will be just fine.
I did stock rim 7 inches wide with 40 mm offset
new rim 7.5 inches wide with 35 mm offset
I have a 2006 2LT 17" rim
Old Mar 3, 2010 | 06:36 AM
frank6060's Avatar
If your buying these on line get documented confirmation from seller these wheels will fit your year and model HHR. That way if they dont fit it's on them. I bought wheels on line last year that were listed for my ride. When I put em on the fronts scraped the outside of the caliper. I was pissed but got full refund with no issue.
Old Mar 3, 2010 | 09:48 AM
prod's Avatar
The factory wheel offset is actually 42mm. That means these will stick out 7mm more.
That shouldnt be a problem, but if it is you can just get narrower tires to avoid contact with fenders.
betterof2evils4
Apr 3, 2017 08:34 AM
FargoFlash
Jul 12, 2011 04:54 PM
