bolt pattern?
Old Mar 21, 2010 | 06:12 PM
kingd1's Avatar
I have an 06 and will be ready to replace tires soon. Was thinking about putting steel rims (painted) with white walls and baby moons. I have heard that if I choose to do this I will have to make some changes. How extensive, and what kind of changes will be required to do this?
Old Sep 28, 2018 | 09:14 PM
Arturo Lopez's Avatar
I'm looking to put some 18 inch rims and wheels in my 2009 hhr but the bold pattern on the rims is
5-115 and the hhr has a 5-110 bolt pattern what kind of adapter do I need and where can I find the adapters
thanks
Old Sep 28, 2018 | 09:40 PM
Well,, if you are into tempting death; you would get an adapter that goes fro 5X110 to 5X115 from a specialty rim shop. Why not just get 18 inch rims that are made for the job?
Old Sep 29, 2018 | 07:12 AM
X2. But if you already have the rims , this style adapter is required
https://www.ebay.com/itm/5x110-to-5x...0720525?_ul=CA
remember , these must have the fasteners torqued properly!
Old Dec 9, 2018 | 12:04 PM
John Manus's Avatar
Adapters
adapters of good quality are made of billet aircraft aluminum and Bolt on to your current lugs and provide a new set of lugs. They are safe when properly torqued . They are used on duallies to allow for mounting of semi wheels and can hold just as much as your factory hub can so not cheating death however spacer plates are a bad thing cause they use some of the students length
Old Dec 9, 2018 | 08:24 PM
d0sitmatr's Avatar
keep an eye on stock stud bolt length, if its above the edge of the adapter, you could have some major problems down the road (pun intended... lol)
seriously though, if studs stick above the lip, you have to either shave them down or replace with a shorter stud.
Biggiedog70
Tires & Wheels
31
Apr 17, 2014 04:36 PM
bartSS
Dec 31, 2008 03:06 PM
Ern
Apr 3, 2007 02:21 PM
slamed87lincoln
May 8, 2006 04:47 PM
fubar
Feb 20, 2006 02:13 PM
