Cobalt SS rim help
Cobalt SS rim help
I bought some cobalt SS rims off craigslist for 130 bucks for the set of 4. The do have some places on the rims that the finish is chipped. ( looks like some sort of plastic/powedercoat) It looks like someone put a wheel weight on the outside of the rims. The damage isn't enough to turn me away from buying the wheels. But I would liek to know if there is anyway that you guys know of to fix the damage so it looks good.
Thanks in advance
John
Thanks in advance
John
The wheels are factory powder coated, so the best way to fix them would be to have them media blasted and powder coated again.
A cheaper alternative would be to sand and paint, although it won't last as long as powder coating them.
Its crazy to that they are powder coated form the factory, Most of the cobalt guys strip them with some kind of aviation paint stripper or something. Will that pull powdercoat off?
[QUOTE=chadpuska;391042]Its crazy to that they are powder coated from the factory..QUOTE]Not too crazy. It's the most efficient way to apply paint. Looks good & lasts long.
Yes
Yes
[QUOTE=HHR_style;391050]i though it was paint. i was at the paint shop and the gm paint book has wheel colors in it. my g6 wheel i know were painted from the factory. and true powdercoat is chem resistant. if solvent takes it off its not powder coat.
i may have lied. i just saw this.
6 - Q. Can MILES New Low-Temperature Chemical Paint Stripping Products be used to Paint Strip Powder Coatings and E-coat from aluminum zinc steel and multi-metal substrates?
A. Yes, MILES New Low-Temperature chemical paint stripping products can be used to paint strip powder coating and Remove E-coating paint from aluminum magnesium brass steel & non-ferrous substrates in addition to removing urethane from TPO & other plastic substrates.
and here is another site about powder coat
http://my.execpc.com/~davewrit/Powder.html
[QUOTE=1Panel2NV;391096]It would be safer/easier/faster to have them media blasted...QUOTE]I would do the same. Stripping with chemicals takes a lonnnnnng time & could damage brain cells. Blast it baby!
If its just some minor chips and you don't want to repaint/powder coat the whole rim. You could clean up any tarnish/ dirt, then with them laying flat face up flow a little clear coat into the chips. Just use a clear coat touch up and flow coats into the chips till they build up till its level with the area around them. Not the greatest fix but it will make the wheels look better and should last a while.
amberelyse
Jul 22, 2006 05:57 PM
