Date code on TPMS sensor
I tried using Google and can't find an answer to this.
On each new sensor I bought are two circles, one big and one small with arrows pointing to numbers.
Both dials go from 1 to 12.
I can read the numbers:
Big Small
7 5
7 5
7 5
6 5
I'm guessing this is the date code for each sensor.
Has anybody found information about this ?
Big Small
7 5
7 5
7 5
6 5
Hmm.
Large circle 7=2007
Large circle 6=2006
Small circle 5= (5th month, May)
Just guessing but hope I'm wrong. Since these are "new" sensors, let's hope they weren't sitting on a shelf for a long time.
I tried the Google search too. Lot of conflicting info on how to date a TPMS sensor. Wonder why the manufacturer can't just put a normal numerical date on them ?
Large circle 7=2007
Large circle 6=2006
Hmm.
Large circle 7=2007
Large circle 6=2006
Large circle 7=2007
Large circle 6=2006
I would think the large 7 to be 2017 ect.
small 5 would be the month.
I tried earlier today to contact the major manufacturers of sensors.
I got tried of put on hold.
Will try later or tomorrow.
Don
I saw those types of markings on cylinder heads and blocks at times when I worked.
But never knew exactly what it represented.
Don
Probably the same manufacturer in China.
A GM part number so maybe they manufacture for GM , not sure but hey they were cheap and so long as they work , great. Did you check the home methods of breaking the tire bead to replace the TMPS sensor, I liked the guy with the two pieces of lumber.
Looks like you can change the battery a bit easier.
You seemed to know what they meant back in 2017. https://www.chevyhhr.net/forums/tire...de-tpms-58831/
