Disable TPMS
It is probably best that you've decided to go with new TPMS for the reasons you've indicated. It's also unfortunate that their implementation is so mediocre, and that the cost of vehicle ownership is directly impacted by this. I don't have to replace my seatbelts every 3-5 years )assuming they work for their intended life) and they haven't failed 3 times since buying the car in 2008. If they had, I suspect GM would be scrambling for a long-term fix to support the expectations that safety equipment actually work well and that the purchaser shouldn't have to reinvest in it so often.
Disable TPMS
While I prefer to have the TPMS system intact, it should be easy to "fool" the system. If anyone has wiring diagrams of the TPMS system to share, I would gladly evaluate a possible solution. I have 20 years experience as a diagnostician in automotive computer/electrical systems. Though I am no longer in the industry I continue to tinker with all things electrical and have equipment to run any necessary tests on my HHR Panel.
Thanks, ChevyMgr. This is the specific info I was trying to find at NHTSA... it looks like my "schedule" was off by a year as I suspected in an earlier post.
Ahh.... the complexities of government regulation. By extension, my 2 other vehicles (1969 and 2006) are probably unsafe and get poor fuel economy. Wait, I did cut my finger the other day on the truck door... and the wife's X does get crummy mileage). Maybe they're right.
If they are gonna be around awhile, they need to make them cheaper, more durable, easier to use and program, and they need to be universal (as in, a single sensor will work with all vehicles, any make or model).
Blame your elected government. Remember they know what you need better than you do.
I just checked the tires manually, w/ a guage & the pressures were fine. I HATE TPMS !!!
Having said all that... I think I'm going to go ahead and blame them anyway. Because it was probably at some overpriced lunch on K Street, between some House Transportation & Infrastructure Committee member and executives from Siemens, TRW, and Continental... each major players in the TPMS market. Worst of all, when TRW guy picked up the check, not only did he likely cause the Rep to violate House Ethics rules, but he probably expensed it... causing TPMS products to go up in price by $0.000001 each. Bastards.
I'm lucky, I was able to find a brand new '07 panel LT 8 mos, ago and it doens't have the temp. warning light. My wife's '09 Altima has it and I just run the custom wheels in the spring and summer with the light on, after awhile you ignore it.
While being a pain, the tpms has saved my butt once already. I cut a tire on my truck and if I didnt have the tpms I would have shredded the tire but luckily was right by a repair shop and had it patched for $17.
