How Wide tire Can i put on My HHR
Old Oct 27, 2019 | 07:05 AM
SheckyB's Avatar
Hi, Guys, I need Tires And right now I have 215 55 16 How Wide can I go? And can you give The numbers Please I want to go a little wider?
Old Oct 27, 2019 | 08:37 AM
Not very much wider, the strut is very close, and the spring plate is also very close.
Maybe 225/55R16
https://www.google.ca/search?q=225/5...&client=safari
Old Oct 27, 2019 | 08:45 AM
I run the 225/55... You're not going to fit any wider than that.
Old Oct 27, 2019 | 08:46 AM
And it would depend on which rims you have, stock or other. Tire width will depend on rim width compatibility.
Old Oct 27, 2019 | 08:49 AM
Greybeard, it’s you , I was thinking run that size.
Old Oct 27, 2019 | 08:51 AM
SheckyB's Avatar
So 205/55R16 91V Would Be Thinner?
Old Oct 27, 2019 | 08:59 AM
There is a discussion about the meaning of tire designations in the Owner Manual.
Old Oct 27, 2019 | 12:46 PM
Yes
https://www.google.ca/search?q=205/5...&client=safari
Old Oct 27, 2019 | 02:00 PM
Another thing to note.. different brands of the same size, or even different models of the same brand, can vary somewhat. So find a size you like that "fits" but then double check the tire manufacturers specs... They may be a tad different than a tire "calculator" shows.
Old Oct 27, 2019 | 07:53 PM
I'm running the 225/50/ but in 17" tires. Max tire height is just over 26" tall, or you risk rubbing the lower strut plate.
