Lug nuts
Old May 6, 2018 | 08:21 PM
bowtieboy68's Avatar
Lug nuts
Looked online for an answer to my probably silly question, but didn't find one.
Will aftermarket lug nuts from an 06 fit an 07?
Old May 6, 2018 | 08:29 PM
That would depend, are they on aftermarket wheels? Here is a thread about stock lug nuts.
https://www.chevyhhr.net/forums/tire...ug-nuts-47798/
Old May 6, 2018 | 08:35 PM
yes, they are for after market wheels.
thank you for the link!
it would appear my searching abilities lack a bit.
i typed in "lug nuts" into the thread search, but came up bupkiss
All the HHRs' used the same thread pitch & length. 12mm x 1.5
Old May 6, 2018 | 08:46 PM
much obliged sleeper
Old May 6, 2018 | 08:59 PM
But if they are aftermarket wheels and lug nuts, the mating surface might not be right.
Old May 6, 2018 | 09:00 PM
Good to see you again bowtieboy68..
RJ has a valid point, stock rims & lugs use a 60* taper.
Old May 6, 2018 | 11:08 PM
thanks for the specs on the lug nuts guys - I'll add that to the Parts List
Goose
Apr 18, 2008 08:35 AM
Goose
Tires & Wheels
Apr 5, 2008 09:14 AM
volcycle
Mar 18, 2008 08:49 AM
Rob
Oct 11, 2007 06:44 PM
GDZHHR
Apr 25, 2007 06:32 PM
