Non-Brembo disc, spare won't fit
Old Apr 2, 2018 | 06:20 PM
mtrhead79's Avatar
Oh i had one question. I hit a big pot hole and bent 1 rim on the front and it has a slow leak and I tried to put spare on and it does not fit over the caliper. I do have non brembo ss front brakes. Do i need a spare from a ss so it clears the caliper? Thx for any help
Old Apr 2, 2018 | 06:41 PM
SS uses the same spare as the LS, LT, so no on getting a spare from one.
Fwiw. The spare doesn't fit on the front of a SS either.
Old Apr 2, 2018 | 06:48 PM
in other words, you will need to move one of the rear wheels onto the front, and put the spare on the rear.
Old Apr 2, 2018 | 06:53 PM
I moved this from that Brembo thread to this new thread.
AFAIK, there is only 1 spare used across all trim levels. The SS still has a little donut spare.
You didn't use the factory SS non-brembo calipers, the aftermarket ones you bought must be bigger. You will probably have to do what we Brembo owners have to do with a flat on the front: Put the spare on the rear, and the rear on the front.
That being said, A donut spare should probably NOT be used on the drive axle of ANY car.
Make sure the spare is properly inflated, it needs much higher pressure. Check the placard in the driver door jamb, probably around 60 psi.
Old Apr 2, 2018 | 07:00 PM
While it’s always best to place equal sized rims and tires on any front wheel drive vehicle.
I’ve only had the one flat, and it was the right rear, but I would have moved the larger tire to the front.
I have the SS non Brembo 11.6 inch rotors and brackets , on Oldblue.
Old Apr 2, 2018 | 07:13 PM
mtrhead79's Avatar
Thx guys. crazy about not putting a spare on front. i wish u could fit a full size tire in the spare tire well. my bent wheel, the leak is slow. i know off a rim in jy the same size but not polished i might go get it to hold me over. its at a u pull it so its cheap
Old Apr 2, 2018 | 08:14 PM
The floor won't fit over it but you sort of can fit a full size spare in the well. The loss of traction from having the weight of a full size spare that far back is a major problem though.... Yeah, I tried.
On to plan B...
Old Apr 6, 2018 | 05:02 PM
Blue_SS's Avatar
NICE. I learn this now as a former owner of one!!!
Old Apr 6, 2018 | 05:05 PM
Blue_SS's Avatar
Actually, now that I think about it, I think the manual tells you to rotate a rear tire to the front and put the donut on the rear only. Still bad.
And, I am getting old...
Chey1995
Jul 30, 2017 08:48 PM
DMarotta
Dec 2, 2014 10:24 PM
Chevy SS
Aug 16, 2009 09:16 PM
