OEM wheels frustration and confusion
Old Dec 19, 2009 | 12:35 AM
prod's Avatar
There are 17" steel wheels for the pontiac G6 that should fit. Not sure why you want them though, Im sure you could get some cheaper at most tire stores.
Old Dec 19, 2009 | 12:09 PM
i like!'s Avatar
here's my update.
there was a real iffy moment putting one on where it was leaking, and we figured it was a screwed up bead. i went home, and it was near flat two hours later. well, i went to buy a new tire, and the kid who was switching it was conscientious and tried to find the problem with the practically new tire he was to replace, and found the rim had a gouge on the inside running towards the lip, and he threw some bead sealer onto it, and i it seems fine, now.
so, now, i need to get rims for my summer tires, 'cause i ain't taking any chances by swapping again.
the stamp on the inside of the OEM rim is 17X6.5, and the bolt pattern is 5X110, so, jay, i don't see how 17.7 and 5x110/5X112 can be OEM although i'm just learning about this stuff so don't be mad if i'm being an idiot.
5X112 will not fit, right? it MUST be 5X110 right?
and, if you don't want hub centering rings, you need to buy rims with the hub bore 65.1, right?
Old Dec 19, 2009 | 01:17 PM
jay loukakis's Avatar
I was buying new wheels that is the size i bought one nothing in stock for 3 months i only nused it for haveing my stock wheels black powered coated gloss black i have the box withh the wheel in about 4 feet from where im now and looking at it. Have a great day, jay
Old Dec 22, 2009 | 11:44 AM
i like!'s Avatar
i guess you have ten holes in your rims, jay? 5X110 (the ones we use) and 5X112(for other cars).
that's not Original Equipment Manufacturer size, which is simply 5X110, 65.1 hub bore, 17X6.5 rim, offset +42mm.
Old Dec 27, 2009 | 04:18 PM
Bro3's Avatar
2009 Bolt pattern size
I have a 2009 panel that I am looking for wheels for. Are the 2009's the same size-5-110? thanx Bro 3
Old Dec 27, 2009 | 10:38 PM
Yes, same for all HHRs'.
Old Dec 28, 2009 | 10:27 AM
JimDaddyo's Avatar
Well thanks, I was just wondering about rim sizes myself. I just put my winter tires on the stock alloy 16" rims just to give me an excuse to shop for some rims and tires this spring. I may go to a 17 x 7 rim for 235 tires. I don't think I want to go any smaller sidewall than a 50 series tire though, so I my go with a 225 tire. Now to find some nice classic looking chrome rims.
Old Dec 29, 2009 | 02:41 AM
I'm not going less than a 50 sidewall myself.. That's low enuff. I still have the oem 215/50/17 Firestones on. I will be going to a 225/50/17, that should be fine for my needs.
Happy Hunting !!!
Old Dec 29, 2009 | 08:13 AM
pjb's Avatar
pjb
Would a 16" rim going on a non-Brembo SS with stock 18s have the same 6.5" width?
Old Dec 29, 2009 | 08:40 AM
ChevyMgr's Avatar
i like!, you are going to need a front end alignment also. I know this because my son took out 2 front wheels on 2 different events, before he took out all 4 wheels and the rest of the underneath of the vehicle.
