powdercoated rims and lug nuts
Old Apr 15, 2015 | 06:49 PM
skyline26's Avatar
To those who have powdercoated their rims, I have a question on how to install the lugs without them chipping up the holes.
I had my winter setup powdercoated and when i install the lug nuts, the paint is chipping like crazy and moisture getting behind the paint the wheel looks like **** now.
I heard something in the past about using washers behind the lugs so it doesnt scratch up the paint? is this true? any other tips?
my gf is wanting to get her rims done but i dont want this to happen to her set.
thanks
Old Apr 15, 2015 | 08:13 PM
When I had my old trucks rims powder coated ( yes red! of course ) they taped off the lug nut contact area for each of the twenty lug holes , they never chipped
The red powder coated WV I have are chipping a little at each lug nut contact point but the moons cover it.
As for washers , no don't do it
Old Apr 15, 2015 | 10:31 PM
If you don't tape off the lug contact area when painting, then you should at least sand that area back to bare before installation and tightening lug nuts.
Skyline. Just consider it a lesson learned with your rims.
Now go ahead and get the Gf's painted. Just follow the prep advice above and you should be OK with her rims.
Fwiw. Putting 100lbs of torque when tightening the lugnuts,,,,hardly any painted surface will survive that.
Old Apr 15, 2015 | 10:33 PM
Never use washers - that's asking for disaster (hummm I've never seen tapered washers except in limited electronic cabinet applications). Tape off the stud holes as noted above is the answer, or sand them out as noted.
Old Apr 16, 2015 | 12:54 PM
skyline26's Avatar
where did you get them done?
Old Apr 16, 2015 | 12:56 PM
At a shop that has since gone out of business!
Old Apr 16, 2015 | 02:08 PM
skyline26's Avatar
i am still trying to locate a good shop around me, too many shady businesses out there
Old Apr 16, 2015 | 04:42 PM
Cat Man HHR's Avatar
If you have an old oven that the wheel can fit in you can buy this and do it yourself:
Hotcoat Deluxe Powder Coat Kit ? Eastwood Powder Coating Kits - Powder Coating Spray Gun
Old Apr 17, 2015 | 08:33 AM
skyline26's Avatar
Should i remove the wheel weights as well? The rims have the metal clip-on ones and also the sticky ones.
If i remove them, can the metal clip-on ones be replaced with all the stick-on style?
Old Apr 17, 2015 | 08:39 AM
Remove everything the rims need to be stripped down the bare metal , I sandblasted my steel rims.
After to balance the wheels , I had the tire shop use stick on tape weights on the inside of the wheel and the shortest valve stems they had!
