Relacement TPMS
Old Feb 12, 2018 | 10:02 AM
Cat Man HHR's Avatar
Relacement TPMS
I have Dorman 974-009 direct fit sensors. These are a metal stem valve assembly. Comes with mounting hardware.
Can use the air pressure method of calibrating them just like OEM.
Cost is less than GM parts.
Look into direct fit for your wheels if need be.
Old Feb 12, 2018 | 03:21 PM
They are metal , so they are for aluminum wheels.
Old Feb 13, 2018 | 04:16 AM
That is correct.
Old Feb 13, 2018 | 06:49 AM
Should move this thread to the Tires & Wheels section.
Old Feb 13, 2018 | 08:59 AM
The amusing thing is that most parts books think that all HHRs have alloy wheels. The salesweasels at Firestone tried to sell the stem kits to me, they are basically a couple of rubber washers and a new nut. The guys at NAPA won't even consider looking at rubber stems, the book says metal and that's it.
315 MHz is the important part of the sensor description, as long as it can mount on the stem you have. Most metal stems and rubber stems with threads will accept them.
Old Feb 13, 2018 | 10:00 AM
FMG, I moved it on over!
thekraut
Aug 24, 2012 05:10 AM
BlackknighT
Aug 19, 2011 07:15 PM
breeze
Jul 3, 2008 02:30 PM
08panelman
Tires & Wheels
Jan 24, 2008 10:50 PM
mitzkity
Feb 18, 2007 12:12 AM
