Snow tire question
Old Feb 9, 2014 | 02:12 PM
Allen S's Avatar
Snow tire question
Gonna snow tonight,want to put my 16 in snow tires on....if I leave my 18s on the back ,will it screw with my abs? There is a difference in overall dia. Would just be for a day or 2....hopefully. thanks
Old Feb 9, 2014 | 02:44 PM
Lucky's Avatar
It will probably set a wheel speed sensor code if there is enough wheel speed difference. After the abs light comes on the abs will be disabled the major problem is before the code sets and the abs is disabled the abs may do some strange things thinking your skidding and I would think that could be unsafe in bad weather. I would not recommend it.
Old Feb 9, 2014 | 05:45 PM
Allen S's Avatar
Thanks...I decided to put all 4 on anyways, good thing.
Old Feb 9, 2014 | 06:49 PM
Lucky's Avatar
Old Feb 10, 2014 | 04:45 AM
You didn't mention what the sizes were of your tires. But good move running the 4 snows!!!
You can use the tire/rim calculator tool at the top of the page to figure out if there is much of a difference in TIRE diameter - the rim size is not the determining factor of course.
Punch in your numbers and it will list out the difference at the bottom in inches and in %.
There must be a threshold for the difference before it starts to affect the ABS system - but I don't think there is any discussion here on it so far. I've run with the mini-spare on the rear for a day or two, and never noticed the ABS complain.
Interesting question man.
Old Feb 10, 2014 | 12:08 PM
Lucky's Avatar
I never though about the mini-spare. I will have to dig into this some more
Old Feb 10, 2014 | 04:50 PM
4 snows are best!! and worth the time to install!!
Kris G
Tires & Wheels
14
Oct 3, 2009 05:34 PM
spirited driver
Sep 15, 2009 06:39 PM
cheroke75
Tires & Wheels
Aug 1, 2007 08:28 PM
