Help with hhr wheel specs
Old Feb 10, 2014 | 04:30 PM
legalay's Avatar
Hello again to all you guys... just needing some feedbacks or expertize opinion.
Im looking to buy some custom wheels for my 2009 hhr wagon.
wheels are identified as to fit the SOLSTICE 2005-up /MALIBU LTZ 2006-UP, as well as the 2005 g5/g6.
but doesn't mention the HHR. below are wheel specs/
Bolt Pattern : 5x110 mm
Offset : 38 mm
Lip Size: 1"
Hub Bore Size: 73 mm
will these fit my HHR without any rubbing?
will I need spacer adapters?
any help will be highly appreciated.
THANKS
Old Feb 10, 2014 | 04:46 PM
you'll need spacers as the Solstice rims show 58 MM offset and an HHR has 42 MM offset , and longer studs as the stockers are too short,
the hubs on the HHR are 65.1 MM read this post
www.chevyhhr.net/forums/showthread.php?t=48853
and this for spacers
http://www.chevyhhr.net/forums/archi...p/t-47657.html
Old Feb 10, 2014 | 04:50 PM
Ya beat me to it Oldblue, got some fast fingers there.
Old Feb 10, 2014 | 04:54 PM
I have to , it's dang cold up here!!!
Old Feb 10, 2014 | 05:00 PM
Guess that's true man, it's snowing here in Carolina with 6-8" forecast by Thursday morning, followed by freezing rain.
Al Gore really blew this Global Warming deal.
Old Feb 10, 2014 | 05:29 PM
so, just do it......
Old Feb 10, 2014 | 08:36 PM
legalay's Avatar
you guys are awesome!! Thanks alot.. Can i get away with just doing the fronts only?.. I don't think the rears would matter much on the rubber
Old Feb 10, 2014 | 08:45 PM
Offset : 38 mm
Lip Size: 1"
If this is really the offset they will fit without spacers. Your description say's they will fit a solstice, but at 38 offset they might rub on the solstice.
Old Feb 11, 2014 | 11:35 AM
retrolled's Avatar
I want this car!
PaulaF
Tires & Wheels
Dec 6, 2014 06:46 PM
8t7vette
Aug 2, 2010 02:09 PM
Michael20832
Aug 18, 2008 01:09 PM
Tony_W
Jun 25, 2008 11:50 PM
Lone Ranger
Jun 5, 2007 06:50 PM
