Tire and rim fit range
Old Apr 5, 2010 | 02:48 PM
wagoneer's Avatar
Question Tire and rim fit range
Can we get a sticky that will give the rim and tire size range that will fit on the HHR? Rim width, bolt pattern, offset range and tire size range for each size rim?
I have been trying to find the offset range for a 16" rim and a brief definition of what offset is. I know it's on here so I was trying to figure it out without starting another post. I failed to do so but if we get a sticky for it maybe the next person looking will have an easier time.
Old Apr 5, 2010 | 02:55 PM
Father Azmodius's Avatar
Offset is how far off the centerline of the wheel the hub mount is. A positive offset means the hub is farther towards the outside of the car, typically known as a FWD offset, where as a negative would be considered a classic RWD offset. Of course manufacturers are putting high offset wheels on RWD cars now, possibly just to make things a bit more confusing for some. Generally some of the info you're looking for is stamped on the inside of the wheel.
Old Apr 5, 2010 | 03:11 PM
wagoneer's Avatar
So for FWD it doesn't sit over the wheel right? What is the range on the positive offset?
Old Apr 5, 2010 | 03:12 PM
wagoneer's Avatar
I meant over the hub
BeanWagon
Jun 30, 2013 10:03 AM
JJ's BLACK SS
Apr 20, 2010 11:34 AM
Yonash
South Pacific
29
Jul 22, 2008 11:11 PM
