Tire size limits
You threw some different wheel and tire sizes out there. The tire answer will depend on wheel size and offset. The 235 width in any tire is going to be a tight fit on an HHR with a drop. Proper offset will be critical. If you are serious about wanting a wide tire AND the drop you will most likely need to roll the lip in the back.
Most 235/45/17 tires look better on an 8-inch wide wheel. That size can look funny on a 7, of course this depends on the actual tire and sidewall construction, but in general you would use that size on a wider wheel.
