Tire size limits
Old Aug 20, 2007 | 06:55 AM
JimDaddyo's Avatar
Thanks for the link btw
Jim
Old Aug 20, 2007 | 07:11 AM
JimDaddyo's Avatar
a 235/45/17 is also a nice match...but again...will the HHR take the width of a 235?
Old Aug 20, 2007 | 01:58 PM
TruckSHOP.com's Avatar
Former Sponsor
You threw some different wheel and tire sizes out there. The tire answer will depend on wheel size and offset. The 235 width in any tire is going to be a tight fit on an HHR with a drop. Proper offset will be critical. If you are serious about wanting a wide tire AND the drop you will most likely need to roll the lip in the back.
Most 235/45/17 tires look better on an 8-inch wide wheel. That size can look funny on a 7, of course this depends on the actual tire and sidewall construction, but in general you would use that size on a wider wheel.
Old Aug 20, 2007 | 02:22 PM
JimDaddyo's Avatar
225/55/16 hard to find...and the wheel size calculater is fun too! I don't really want to roll the lips on the wheel wells.
Old Aug 20, 2007 | 03:35 PM
Former Sponsor
The 225/55/16 is a fairly common size, you should be able to find several tires to choose from. Are you looking for a specific kind of tire?
Old Aug 21, 2007 | 07:02 AM
JimDaddyo's Avatar
Not really, a nice summer radial that is decent in wet/dry and a smooth sidewall without all those stupid little sipes around it.
Old Aug 21, 2007 | 10:17 AM
HHR ROD's Avatar
Tire size
I just put a set of 225,45,18 on yesterday. lots of room and clearence :twothumbs will show photos later
Old Aug 21, 2007 | 10:36 AM
captain howdy's Avatar
Do you have different rims than the factory ones in your pics? I'm trying to figure out how you fit a tire meant for 18" rims on the factory 17" rims.
Old Aug 21, 2007 | 11:55 AM
HHR ROD's Avatar
Cool Tire size- rims
Yes , I also put 18" rims on the ROD! I am putting the photos on members photos under "HHR ROD" CHECK THEM OUT
Old Aug 21, 2007 | 12:00 PM
Nice rims.
