Tire size limits
Old Aug 21, 2007 | 05:10 PM
JimDaddyo's Avatar
nice ride too
Old Aug 21, 2007 | 05:31 PM
MickeysHHR's Avatar
I lowered mine and had 245/40/18s and had to roll drivers rear fender, and front tires rubbed if i turned hard left i recently bought new tires again and went with 235/40/18 and no problems, probably to low profile for your taste though.
Old Aug 22, 2007 | 06:22 AM
JimDaddyo's Avatar
yup, profile is a bit too low....but the important part is that a 235 fits without having to bend the metal. Are you using the stock offset and width rim?
Old Aug 22, 2007 | 06:56 AM
JimDaddyo's Avatar
So, It's come down to 2 sizes. 235/50/16, harder to find but prefered for me, or a 235/45/17, I would like a bit more sidewall, but would settle. For rims, hmmm, a 7.5 or 8 inch width? I don't mind a bit of bulge in the tire. Offset/Backspace, who knows??? I don't want to alter the sheet metal. Suggestions????
Old Aug 26, 2007 | 07:05 PM
JimDaddyo's Avatar
hmmm...bump.
What is the stock backspace...34mm?
Old Aug 27, 2007 | 07:31 AM
  #26
JoeR's Avatar
Originally Posted by JimDaddyo
hmmm...bump.
The stock offset (not backspacing; that's different) is 42 mm.
Old Sep 5, 2007 | 08:58 AM
  #27
JimDaddyo's Avatar
oops...my bad...got my terminology mixed up...Kinda settling on a 235/50/16. There is only a 0.2% difference in diameter. So, I am looking for suggestions on rims...width and offset. I don't mind a bit of sidewall bulge, 8" wide rims perhaps?? But the offset has really got my head spinning. I don't want to bend the fender lips, so I would like the extra width to go inboard if possible, without rubbing suspension. That would mean LESS offset, right????, or is the + in +42mm offset mean that it is going to the outboard side of the rim, meaning I need more offset.....OOWW, my brain hurts,,lol
Jim
Old Sep 5, 2007 | 09:04 AM
  #28
JimDaddyo's Avatar
Hmmm. found this
http://www.1010tires.com/WheelOffsetCalculator.asp
Looks like an 8" rim with a 45 mm offset will put an extra 3mm on the outside and 9mm on the inside...??? right? Will that work?
Old Sep 26, 2007 | 06:49 PM
  #29
stelerz's Avatar
20's
I'M RUNNING 20 X 8'S ON MY 2007 HHR BY AMER RACING. WITH NITTO TIRES AND ITS BEEN LOWERED WITH EIBACH SPRING KIT BY THE DEALERSHIP.
Old Oct 4, 2007 | 01:37 PM
  #30
intofocuszx3's Avatar
ok question i have a LS WITH 16" HUBCAPS i was just going to lower the ass of my HHR. I think it's 1.6" and I was going to put 235/50/17 on my car will that be ok or will that be to wide of a tire.
