Torque Thrust Wheels
hey all, my first post here. I have a 2008ls and have searched and keep hearing that they dont make torque thrusts for our HHR's. will these from ebay not fit? I keep reading that they must be custom drilled. ad says these fit.
16 16x7 American Racing Torq Thrust M 5x110 35mm Black Wheels Rims | eBay Item specifics Condition: New Manufacturer Part Number: AR105M6752B Size: 16x7 Surface Finish: Black Rim Width: 7 Warranty: Yes Bolt Pattern: 5x110 Brand: American Racing Offset: +35mm Style: Torq Thrust M Backspacing: 5.5" Rim Diameter: 16 Finish: Black thanks |
Welcome to the site!! Nice find theses are very cool rims
the specs claim they will fit, now our buggy's have a 42 mm offset and a thinner 6.5 inch width but they do claim they will fit and advise how they determine that fitment. Also they warn you will need different than stock " custom lug nuts " another $30.00 plus shipping so as Ceasar once said Cavet Emptor or something close to it, maybe buyer beware! |
Originally Posted by zapshd
(Post 769574)
Originally Posted by Oldblue
(Post 769576)
the specs claim they will fit, now our buggy's have a 42 mm offset and a thinner 6.5 inch width but they do claim they will fit and advise how they determine that fitment. Also they warn you will need different than stock " custom lug nuts " another $30.00 plus shipping so as Ceasar once said Cavet Emptor or something close to it, maybe buyer beware! Not really, as you will find an offset range of 35-42, listed for most stock HHR wheels...:smile: Pilot/Wheel ALY05247U20N at AutoZone.com Pilot/Wheel ALY06584U88 at AutoZone.com |
but the stock rims are 42mm offset, so why call me a liar???
(Post 769604)
Just saying, that you will find stock HHR wheels listed, anywhere from, 35-42 offset...:D The OP wanted to know if those wheels would fit, & yes, they will fit fine...:twothumbs: |
nor did you read this from back in May2006, posted by SoCalHHR
The standard offset is 42mm on the HHR's stock wheels. An offset of LESS than 42mm will stick OUT more. An offset of MORE than 42mm will tuck INSIDE the wheelwells more. and knowing that the after market makes claims then does not back up these claims, I gave the correct answer, to avoid misleading the OP to order rims that could possibly fit or could possibly not fit, causing tire damage, suspension damage, out of pocket expense for shipping and handling and most of these company's will not accept a return once the rim has a tire mounted to it. |
now that ive started WW3 LOL the consensus is these wheels will fit, but they will stick further out than stock? I was going to stay with the 16's because my current tires are like new, would the 17's they sell fit better?
Item specifics Condition: New Manufacturer Part Number: AR105M77552B Size: 17x7.5 Surface Finish: Black Rim Width: 7.5 Warranty: Yes Bolt Pattern: 5x110 Brand: American Racing Offset: +45mm Style: Torq Thrust M Backspacing: 6" Rim Diameter: 17 Finish: Black dont mind the wheels sticking out further because of wider tires, just not because the offset is not correct. |
Torque thrust Ms
Helped a member get a set of torque thrusts re-drilled a while back (probably didn't offer them when he needed them) here's what he posted as specs:
Originally Posted by ROMEO_Rocks
(Post 650643)
It doesn't matter at all where the shop is that can sell me a redrilled wheel, as long as they are willing to ship it.
If they don' offer international shipping, i can use a mail forwarding service located in the US to do the export. The wheel i need is an American Racin Torque Thrust M with black finish, dimensions: 17x8", bolt pattern 5x4.5" redrilled to 5x110mm, offset 30mm (if possible with 5mm shaved off the backside for 35mm offset) Depending on the machine shops capability to shave 5mm off the wheel back, i might even need two of these wheels. Also i'd like to order a set of 4 hub centric rings and conical lugnuts for these Torque Thrusts. The hub centric rings have to be custom made, which might be possible for the same machine shop that can redrill my wheel(s). |
no WW3 here , just facts, the 17's with 7.5 inch width and 45 MM offset MIGHT fit also, I just think it would be best that you measure three time fit and spend once!
3MM is much closer than 7MM to the factory spec of 42MM. now that being said, there are multiple members who have had to use spacers , change wheel studs, and other things to get their wheels and tires to fit and not rub the struts or the inner fenders. But that's another can of worms to fish with. |
I agree about double ching, the company selling them says either set fits fine, and to call them or AR directly if I have any questions.
