TPMS for steel wheels
Old Dec 9, 2017 | 06:11 PM
Steve Karadi's Avatar
I have a 2009 2 LT and I want to change my wheels to 16" steel smoothie. I understand that the toms sensors from my stock alum rims won't fit. Is that correct ? Where can I get sensors that will work ? Thanks
Old Dec 9, 2017 | 06:16 PM
Hi Steve, to the forums!!
I think you mean TPMS,
Your sensors, if original, are very likely near the end of their life anyways(non-replaceable batteries). You should be able to get the proper sensors from many sources. EBay, tire shops, Amazon, etc.
Old Dec 9, 2017 | 07:32 PM
I don't know any reason they won't work. What reason was given?
They are available everywhere auto parts are sold. Just be sure they don't think you have a PT Cruiser.
Old Dec 9, 2017 | 07:59 PM
I read on a different thead that all I have to do is change the valve with one that matches the new rim and has a nut in it to attach the sensor to it. You're right about getting new sensors too.
​​​​​​​To answer the other guys comment... the valve stem is different for aluminum wheels vs steel wheels. The thickness of the metal is not the same
Old Dec 9, 2017 | 10:10 PM
Well then get rubber stems. The sensors are the same.
Old Dec 10, 2017 | 08:34 AM
Steel rims ... rubber TPMS sensors stems 25920615
Aluminum rims ..metal stems 15202272
BlackknighT
Aug 19, 2011 07:15 PM
spotty
Tires & Wheels
May 13, 2011 01:01 AM
