what kind of rims on my 08 dark grey panel
Old Mar 29, 2009 | 12:24 PM
Panel08's Avatar
want kind of a muscle look something like aluminum torque thrusters i also want it staggered lik an in with fat tires im not sure what size of tires or rims to go with what do you guys think i should do
Old Mar 29, 2009 | 01:06 PM
HipHotRod's Avatar
Check out TKHHR's ride
He has torque thruster-ish wheels on his panel. Give you an idea what they will look like.
Old Mar 29, 2009 | 05:11 PM
mrkil's Avatar
614 [BLACK/YELLOW] By NASCAR
Bolt Pattern: 5x110
Offset: 38
$128 usd
available for the hhr in 16 17 and 18"
Old Mar 29, 2009 | 08:17 PM
HHorange's Avatar
As for what rims you go with that's a personal taste thing....
Going for a staggered look might give you a big problem. The ABS brakes and the traction control will be effected by staggered tire sizes. You can change widths without to much problem as long as the outside diameter of the tires front and rear are the same.... you could play with different size rims front and back with different aspect ratios (ie 50,55,60) as long as the over all outside diameter in the front and the back are the same.
For example something like a 17 inch rim in the front and a 16 inch rim in the rear with 50s in the front and 55 or 60 series tires in the rear. you could get the same size outer diameter and have larger side walls in the rear..... It would take a little to figure out exactly what sizes you would need.
Just my .02$
Old Mar 29, 2009 | 09:57 PM
Panel08's Avatar
yea i like TKHHRs rims but id want more tire less wheel and a more matte or flat color those nascars are pretty nice
Old Mar 29, 2009 | 09:59 PM
xzombiex66's Avatar
Yea i like those Nascar wheels, never saw those before.
Old Mar 29, 2009 | 10:55 PM
twistrman's Avatar
mrkill - i have looked at these in the past, and was really tempted, besides the fact that they have nascar stamped all over them.
Otherwise it is a pretty sweet rim. I had even did a quick photoshop of them on mine. I also have the calipers mocked up in these, but they are yellow for real now.
Seeing them now, still tempted... Where did you see the other sizes and prices. I am seeing $153 each at tirerack for 18's. Not bad for a set of rims with a bit of style and not too much money. Still wish i could have gotten some black proplusions with tires on ebay when they were around. Hard to find now.
Old Mar 29, 2009 | 11:25 PM
Panel08's Avatar
man thats cool how you did that on photoshop something more torque thrustery with the aluminum lip and and the grey center but its like a sprayed on grey that feels rough my brother has um on his 65 GTO i know they r boyd coddingtons but idk what kind
Old Mar 30, 2009 | 06:03 AM
mrkil's Avatar
http://www.performanceplustire.com
Old Mar 30, 2009 | 11:19 AM
220's Avatar
220
i looked around and untill you start spending big bucks the 18 solstar rims look cool their a thread check it out
