Which wheels from other GM models will fit the HHR?
Old May 6, 2022 | 09:54 AM
  #101
ScareDe2's Avatar
Originally Posted by KArthur
I still like the Solstice wheels the best... but I am biased.
Are they 17 or 18 inches?
Old May 6, 2022 | 10:04 AM
  #102
ScareDe2's Avatar
Maybe the color of the HHR affects the results you gonna get with a particular mag.
Old May 6, 2022 | 03:54 PM
  #103
PulpFriction's Avatar
Originally Posted by sleeper
Are those the "PVD" chrome coated ? Ford has a lawsuit against that powder coating on their rims..
PVD doesn’t tell you much in the context of car parts. It’s a marketing term derived from part of the the process to get the finish they’re talking about.
PVD is Physical Vapor Deposition, where various metals are vaporized and condense on the part to make it shiny. I have some “black chrome” wheels that were marketed as PVD. I think they started with black paint or powder coat, then vapor deposition of a shiny metal, probably aluminum, probably not chrome, then typically catalyzed automotive clearcoat or something similar. They are pretty corrosion resistant and hold up well when maintained like paint because, well, that’s what it is. Obviously BIG TROUBLE when someone tries to maintain it with chrome polish.
In Cleveland there’s a company that will refinish you alloy wheel with a process like that for about $1000 per 4.
Pic of my Foose Legends marketed as black chrome PVD:
Old May 6, 2022 | 05:40 PM
  #104
heathenhhr's Avatar
Originally Posted by Oldblue
These Moon Salt flats are very cool!
where did these come from? I'm not finding any in 5x110
Old May 6, 2022 | 10:21 PM
  #105
ScareDe2's Avatar
You can see here an HHR with the casino mags and they don't look as pretty, not sure but the color of the car plays a role I believe :
These mags look great for this HHR.
Old May 7, 2022 | 07:07 AM
  #106
they are Moon Equipment Salt Flat . From SoCal Speed shop, they closed in 2020, so you wouldn’t be seeing them anymore.
Old May 7, 2022 | 07:27 AM
  #107
heathenhhr's Avatar
sad, I found SoCal wheel shop... and looks like there's a couple brands (American Racing being the big one) that still makes that style... but I couldn't find any in our bolt pattern... stupid 110
I've also been looking for ideas on what to put on my van (eventually), the local guys all want me to build a 70s street van (fender flares, lowered front, shag), but that's just not my style
Old May 8, 2022 | 01:03 PM
  #108
KArthur's Avatar
The tires I mounted are 225/45/18. I did replace my struts with new KYB struts. Not using any spacers or longer studs..... but it is a very close fit around the strut area. The tires do not rub anywhere, even when turning full left or right.
Old May 8, 2022 | 08:02 PM
  #109
Those look hot, ever think of lowering yer ride a bit to give it some less altitude ?
Old May 8, 2022 | 08:06 PM
  #110
From what I've seen I will stay from PVD coated rims.. Guy across the hollow has them factory Ford on his uptown new Ford P/up. & the PVD is peeling.. Truck is big $$, but rims look cheap peeling.
