Will 2006 HHR wheels/rims & tires fit 1998 Malibu?
Our 2006 HHR has died and before it is scrapped I want to transfer the wheels/rims & tires to our daughters 1998 Malibu which is in need of new tires. The HHR tires are relatively new and I would hate to just scrap them.
The 2006 HHR tire size is 215 / 55R16 / 93H. The 1998 Malibu tires read, 215 / 60R15 / 94H. Im just simply not an authority on tires and could use some advice if these wheels & tires would fit the Malibu. Any help would be appreciated.
Try this to learn what the sidewall code means
http://www.coasttire.com/tires/readsidewall.asp
Looks like I found the answer to my question about the actual wheels/rims. The HHR has a bolt pattern of 5 x 110 and the Malibu has a bolt pattern of 5 x 115. It appears that Im out of look being able to use the HHR wheels on the Malibu because of the different bolt pattern. This is a bummer!!!
Our HHR has 235,000 miles on it and the engine has given out. Need a new engine and a lot of front end work. Total repair cost is in the $3,500 range. So we are going to scrap it and buy a new vehicle.
Also just realized that I cannot use the HHR tires on the Malibu. The HHR tires are R16's and the Malibu needs R15's. Cant put a 16" tire on a 15" rim no matter how much air you pump into them, lol. So I'm totally out of luck with the tires.
