Will these fit?
Old Mar 24, 2015 | 10:17 PM
Just take off one of your stock front wheels and bolt up one of the bare Catera rims.
That would be the easy way to find out since you already have them.
Old Mar 25, 2015 | 12:37 AM
prod's Avatar
Yes mine were hitting the front calipers, used 1/8 spacers. You could grind the edge of the caliper I guess, but spacers are easier.
Old Mar 25, 2015 | 12:43 AM
merged the two threads............
Old Mar 25, 2015 | 10:35 AM
tireman1554's Avatar
Bolt pattern is correct however; the backspace and offset is a bit different. As mentioned above, a spacer may be needed but NOT recommended.
