Will these rims fit?
I've never really been into rims so I pretty much know nothing about sizing, fit, etc. However, I would like to spiffy up my new HHR with Chrome wheels. The car is an LS stock with 16" wheels currently. Would the wheels and tires listed below fit my car? And if so how would the size change effect the car's performance/mechanics, if at all?
18" KBA chrome rims with Kumho Ecsta ASX low profile tires.(235/40 R18) |
yes they will but i suggest you get a 245.
The tires should be ok depending on the backspacing. That is, if it's the right bolt pattern.
245 series might be pushing it depending on the width of the wheel. |
Originally Posted by 1Panel2NV
(Post 401264)
rims
The seller of the rims says they are "the universal 5 lug pattern" whatever that means.
What is backspacing?
Thanks guys! |
Originally Posted by ecaryn
(Post 401267)
Seller probably thinks it fits all 5 lugs.....:roll: |
Originally Posted by solman98
(Post 401329)
Unversal means a lot to different people. It probably has two different bolt patterens. If the seller does not know the bolt pattern, find out what they came off of. We can then look to see what that bolt pattern. The HHR has a 5x110 pattern and it's not a very well used pattern.
Seller probably thinks it fits all 5 lugs.....:roll: Bolt pattern width warranty (someone posted this a while back) Brakes (Big rims weigh more) I dont know a lot about cars but this is just my opinion from my past experience with my impala. I could be wrong. |
Better deal
Ok, nix the first set of wheels. I found a better deal on some I like better. So, then will these fit?
18" Tyfun Wheels Model # TW752, Size 18 X 7.5, "Universal Lug Pattern". The rims came off of a Pontiac G6 car. These tires are some kind of low profile variety. Thanks all! |
Doesn't matter if they are universal, they need to be 5x110 lug pattern to fit with no modification.
| All times are GMT -5. The time now is 05:09 AM. |
