2008 ss ecm pinout
Old 08-07-2016, 04:01 PM
ULOS2A6's Avatar
2008 ss ecm pinout
Does anyone have the PINOUT for the ECM for a 2008 SS 5 speed?
Here is what I found for a Cobalt but it shows 60 pins and my connector at the ECM shows 58 pins.
Attached Thumbnails 2008 ss ecm pinout-image.gif   2008 ss ecm pinout-image.jpeg
ULOS2A6 is offline
Old 08-07-2016, 05:12 PM
Technical Moderator
Does this help? Looks the same to me. Mitchell says that connector X-1 is 96 pins and X-2 is 58 pin
donbrew is offline
Old 08-07-2016, 05:16 PM
Powermizer's Avatar
This is all I can find
Powermizer is offline
Old 08-07-2016, 05:29 PM
Technical Moderator
So does AllData.
donbrew is offline
Old 08-07-2016, 05:32 PM
Powermizer's Avatar
Ha, killing me, I had the image just like that and couldn't figure out how to post it. Thanks donbrew!
Old 08-07-2016, 05:47 PM
Technical Moderator
Snipping tool, then attach.
donbrew is offline
Old 08-07-2016, 06:56 PM
ULOS2A6's Avatar
Thanks so much! This is exactly what I need.
ULOS2A6 is offline
Old 08-07-2016, 06:58 PM
ULOS2A6's Avatar
Powermizer, Donbrew,
Thanks for the info! This is what I needed.
ULOS2A6 is offline
Old 08-07-2016, 07:13 PM
ULOS2A6's Avatar
Donbrew,
Is it possible to send me the 1st diagram that has the wire colors where it might be more readable? I can't see the descriptions or the numbers clearly. Thanks again!
ULOS2A6 is offline
Old 08-07-2016, 07:25 PM
Technical Moderator
Pin numbers and wire colors are in the chart in post #4.
It looks to be exactly what you already havr.
I will try to PM a pdf.
donbrew is offline
Quick Reply: 2008 ss ecm pinout
