Spark plugs
Old 08-29-2014, 09:49 PM
farmboyhhr's Avatar
Spark plugs
Hey i have a question about my 2.2. It is acting real sluggish and has around 110,000 miles and i believe its the original AC Delco plugs that are still in the car. It literally has very limited acceleration power and also the fuel economy is decreasing as well. Is the plugs all i need to worry about?
farmboyhhr is offline
Old 08-29-2014, 10:15 PM
Tyler Harvey's Avatar
Spark plugs are a good start.
Tyler Harvey is offline
Old 08-29-2014, 11:08 PM
Frenchy42's Avatar
Spark plugs fall under the 100k mile maintenance, so like Tyler said, its a good place to start. Go with the ac delco OEM replacements. I've heard from a few people on here that anything else can cause issues with the motor not running right and throwing codes.
Frenchy42 is offline
Old 08-30-2014, 12:00 AM
While you are doing the plugs, check and change the air filter as necessary.
whopper is offline
Old 09-16-2014, 12:33 PM
isaacm66's Avatar
I actually had my spark plugs changed this morning at 103000 miles and this is what the old one's looked like. Keep in mind i just changed my plugs because i knew it was time not because of any performance problem. I am getting about 28mpg consistently. I did my plugs, air filter, some fuel system treatment, i wonder if my mileage is going to even get better. They look pretty scary too me.
isaacm66 is offline
Old 09-16-2014, 02:16 PM
Twistedtat's Avatar
Maybe Im old school but I still cannot believe a plug last 100,000 miles.
Twistedtat is offline
Old 09-16-2014, 03:54 PM
Doc brown's Avatar
Clean your throttle body also. You'll need to take it off to do it proper like. And disconnect the battery because when you put it back on it will likely throw a code otherwise.
Doc brown is offline
Old 12-27-2014, 02:35 PM
farmboyhhr's Avatar
I did change the spark plugs and changed my air filter and car seems to be running smoother but after i got everything hooked back up i now have a Service ESC and Service Traction on my display...help
Old 12-27-2014, 03:13 PM
Technical Moderator
My money says you forgot to plug the MAF back in.
donbrew is offline
Old 12-27-2014, 04:49 PM
Yes I think Don is right about that MAF sensor connection make sure it is connected
Oldblue is offline
Quick Reply: Spark plugs
