Engine problem
Old 02-01-2017, 10:18 AM
Timing chain guide is worn out, my 2.2 sounded similar until I changed the timing chain and guides . I'd also recommend changing the balance shaft chain and guides, there are many kits on EBay that will include even the waterpump, while your in there and got your hands dirty change the water pump too.
Oldblue is offline
Old 02-01-2017, 08:17 PM
Topemo's Avatar
Thank You Oldblue.
Slowly i am starting to see what has to be done (unfortunately) . Logistics and finance director will cut off my head with a blunt spoon All of us will die, somehow
Thats how i see it:
I will need that - 00-11 GM 2.0L 2.2L 2.4L Engine Timing Chain Kit Balance Shaft Set Water Pump L61 | eBay m i right?
that - For 06-16 GM Intake & Exhaust Camshaft Position Actuator Solenoid 2.0L 2.2L 2.4L | eBay
this fella - Stant 14698 Engine Coolant Thermostat fit Buick LaCrosse 10-12 L4 2.4L 2384cc | eBay
Of Course if i've made a mistake in those parts, please fell free to straighten me up.
When i'll finish with that, and the coolant leak will be there where he is now. Then i will start to think what's next.
If i miss sth let me know please.
Oh btw look what i found when i tried to get some specific information about my car:
3GNDA53P08S610822 Chevrolet HHR 2008 - VinDecoderz.com is a free VIN number lookup and vehicle history report provider# I wonder if those are real information. Best part on Campaings and issue ID
Again, thanks to all of you for your help
Topemo is offline
Old 02-02-2017, 09:34 AM
A big no on the Stant thermostat
This is the AC Delco thermostat, it will open within the time frame the computer is set for and doesn't have the rubber ring in it like the Stant does.
http://www.jcwhitney.com/p3042205/sku-3503285.jcwx
Oldblue is offline
Old 02-02-2017, 09:40 AM
If it were me, I might diagnose the coolant problem before I put money into buying other parts. You may decide, with all of the problems, to replace entire engine.
RJ_RS_SS_350 is offline
Old 02-02-2017, 09:49 AM
Technical Moderator
https://www.chevyhhr.net/forums/gm-r...-status-50716/
https://my.chevrolet.com/recalls?vin=3GNDA53P08S610822
All of yours have been performed.
4 of the "campaigns" are really one fix the "ignition recall". The "locks" recall was a piece they mailed to owner to stick on the dash compartment latch. The other "airbag" applies to cars without side curtain air bags, they put some padding in the headliner where the airbag would be.
Those "issues" are all of the wacko reports to NHTSA from people unhappy with GM service.
Sometimes, too much information is a dangerous thing.
However, you do have a couple of "special extended" warranty items i.e.: Power steering and transmission interlock.
donbrew is offline
Old 02-03-2017, 06:18 AM
  #26
Topemo's Avatar
Thanks for corrects Oldblue. Other parts looks fine to You?
RJ_RS_SS_350 - i know what you mean when the cost will be higher than buying new engine i will do that for sure. If i will find one
Donbrew - thanks for info. I cant find there any info about what was done or not. Anyway there were no sales of hhr in Poland and i think chevy, opel etc will wash hands clean, im sure of that. Theres no reason to put steam on that
Topemo is offline
Old 02-03-2017, 08:24 AM
  #27
Technical Moderator
The car is an Opel/Saab. They built Saabs in the same factory. Opel designed the engine. Opel must honor warranty claims.
One of the links in my post is for your car. There are no outstanding recalls on your car, which means they were done.
If your power steering goes out or your key gets stuck in the ignition you are covered by GM/Opel.
If any work was done by a GM service department the Opel dealers computer should be able to find it.
donbrew is offline
Old 02-03-2017, 09:42 AM
  #28
Topemo's Avatar
Ahh now i get it :) n1, i owe all of You i will deliver real ones when ill finish with car
Topemo is offline
Old 09-01-2018, 10:00 AM
  #29
Topemo's Avatar
Hi everybody :)
Im still with my HHR. Last problem's end with engine swap ;(
I want to do some work and i have questions about parts.
I want to change:
Clutch and timing chain.
Some links:
Chain: https://www.rockauto.com/en/moreinfo...41024&jsn=1858
Clutch: https://www.rockauto.com/en/moreinfo...41024&jsn=1856
Water pump: Product Detail
Do You think it is a good choice? Maybe there is a better option?
Thanks for advice
Topemo is offline
Old 09-01-2018, 02:20 PM
  #30
Those will do, but didn’t you change the timing chain when you swapped the engine?
and while you’re changing the timing chain and water pump , change the balance shaft chain
Oldblue is offline
menance
12-22-2010 06:14 PM
urbexHHR
11-03-2010 07:00 AM
06gray2ltHHR
2.4L Performance Tech
08-01-2009 10:45 PM
ts5p
10-06-2008 02:47 PM
Black Rose
12-07-2007 11:28 AM
Quick Reply: Engine problem
