Torque Specs? (Wheel bearing bolt, spindle nut)
Old 03-08-2009, 01:04 PM
8t7vette's Avatar
Anyone have a FSM handy or know what the torque spec is for the spindle nut and wheel bearing bolts?
Thanks
8t7vette is offline
Old 03-08-2009, 06:39 PM
ChevyMgr's Avatar
Hub bearing bolts are 85 lb ft.
ChevyMgr is offline
Old 03-08-2009, 11:04 PM
Lucky's Avatar
Axle nut 81 ft
Lucky is offline
Old 07-07-2010, 09:16 AM
nickster214's Avatar
thank you
nickster214 is offline
Old 07-31-2010, 08:40 PM
Question
hey does anyone know the torque spec of the lower control arm bolts ball joint bolts?
Old 08-02-2010, 04:05 AM
ChevyMgr's Avatar
Install the drivetrain and front suspension frame bolt (4) in the frame (6) and tighten the frame bolt (4) to 100 N·m (74 lb ft). Using an angle meter rotate the frame bolt (4) 180 degrees.
Install the front lower control arm brackets (5) and the lower control arm bolts (2) and tighten to 55 N·m (41 lb ft).
Install the front lower control arm (3) in the steering knuckle (1).
Install the lower control arm bolt (3) in the steering knuckle (2).
Install the lower control arm nut (1) and tighten the lower control arm nut (1) to 50 N·m (37 lb ft). Reverse the nut 3/4 of a turn. Using an angle meter rotate the lower control arm ball stud nut (1) 30 degrees.
ChevyMgr is offline
Old 08-02-2010, 02:09 PM
Good info & pics... All saved (of course)..
sleeper is offline
EZ4U2CHere
Maintenance and Upkeep
07-11-2013 01:57 AM
shortonmoney2
2.0L Performance Tech
08-12-2012 04:37 PM
harleysshhr
08-24-2010 08:36 PM
intofocuszx3
03-18-2010 07:08 AM
Navyflyer11
08-17-2007 10:19 AM
Quick Reply: Torque Specs? (Wheel bearing bolt, spindle nut)
