Sway Bar Bushings
Old 04-10-2013, 11:42 PM
Originally Posted by VinceP
Try Energy Suspension 9-5161 or 9.5161 as a part number. If I remember correctly that is the ones I used.
Hey, thanks guy - that really helps.
whopper is offline
Old 04-11-2013, 09:13 PM
alexrckid's Avatar
http://www.energysuspensionparts.com...sp?prod=9.5161
http://www.partspro.com/catalogpg/20...ion226-228.pdf
alexrckid is offline
Old 05-16-2013, 01:33 AM
cornwalis's Avatar
Does moog not make. Sume or movtech
cornwalis is offline
Old 05-16-2013, 09:29 AM
thaanks for the link, I just ordered a set of these bushings, my originals are worn out after 212,600 klms
Oldblue is offline
Old 05-16-2013, 12:53 PM
alexrckid's Avatar
216 ++.....like the energizer rabbit..........gotta love these HHR's....i sure do.
Old 05-17-2013, 09:11 AM
pbatmen's Avatar
I just replaced mine on Sunday, with a set from ebay, same as the ones I replaced a couple of years ago that I picked up at the chevy dealership, the were like 15 bucks shipped and OEM.
pbatmen is offline
Old 05-17-2013, 08:51 PM
I picked up the recommeded set today at autozone (were in-stock), and will hopefully get them installed shortly (which means within the next couple of months) :)
Will be great to get rid of the thunking on small bumps.
Thanks VinceP.
whopper is offline
Old 05-18-2013, 04:21 PM
VinceP's Avatar
Thanks VinceP.
Glad I could pass the info along. I believe I got the info from someone here.
Have had mine in about 6 months or so I guess and no issues.
VinceP is offline
Old 05-19-2013, 09:26 PM
alexrckid's Avatar
Thanks VinceP.
only thing that i did when i swapped to the energy suspension bar mounts was to install 90 degree zerk fittings rather than the "zero" degree supplied fittings. with them twisted at the proper angle, makes greasing them a breeze(behind the front tires).....i "locked" the fittings at the right angle with some jb weld...........
Old 05-20-2013, 12:42 AM
GOod tip on the zerks - I was planning on checking that out to see if it would be worthwhile. Red loctite would probably also work to lock them in place - but I am not sure how it would react with the bushings themselves, as loctite can be pretty nasty to paint and some plastics. Great tip though. :)
whopper is offline
Quick Reply: Sway Bar Bushings
