Installed the Rear Anti-Sway bar tonight
Old 06-08-2007, 09:13 PM
bigallis1's Avatar
Got around to installing the Progress Technology rear anti-sway bar tonight.
Check out my gallery for the before and after pics.
bigallis1 is offline
Old 06-08-2007, 09:16 PM
courthousedeb's Avatar
So did you take it for a drive? What do you think of it? Did you feel the difference? Enquiring minds want to know...so I'll ask.
courthousedeb is offline
Old 06-08-2007, 09:17 PM
Love the ramps!!
jx3 is offline
Old 06-08-2007, 09:22 PM
bigallis1's Avatar
Sorry I forgot to mention the details of the install process.
The install was very easy in my opinion. Took about an hour total.
Unfortunately as I was just finishing up, it got real dark and started to rain.
I decided to wait until tomorrow to do the test run. I will post my results.
Old 06-08-2007, 09:41 PM
WOW!!
I'm not doubting or slamming but its only 4 bolts. Took me about ten minutes. I think most here who've done it were about the same. All you should have had to do was crawl under and bolt it up. With the ramps it should have been a breaze.
Did you do other stuff too?
GDZHHR is offline
Old 06-08-2007, 09:46 PM
sjssk's Avatar
Do the bolts go into existing holes?
sjssk is offline
Old 06-08-2007, 09:57 PM
bigallis1's Avatar
Yes, the holes are there from the factory. The install kit has 2 narrow plates with 2 welded nuts on each plate. They slide into the rear suspension housing and the bolts for the sway bar secure to them.
Old 06-08-2007, 10:00 PM
Therein lies the problem. Those damn plates can be a little tricky...especially if you don't have very nimble fingers...and I've got some arthritis starting up, so it was a little tougher for me than some others.
Old 06-08-2007, 10:06 PM
JimZ_HHR's Avatar
Installed mine without use of ramps or jacking up.. was quite simple.
JimZ_HHR is offline
Old 06-09-2007, 12:26 AM
The important thing though is that its done and your HHR will handle MUCH better!
GDZHHR is offline
Quick Reply: Installed the Rear Anti-Sway bar tonight
