Year of this HHR?
Old 04-19-2012, 08:07 AM
nwhite's Avatar
Year of this HHR?
Good morning, would anyone be able to identify the year of this HHR? Thanks much.
nwhite is offline
Old 04-19-2012, 08:13 AM
chefhhr's Avatar
I think that's one of the earlier year models because of the small GM badge at the bottom of the front fender.
chefhhr is offline
Old 04-19-2012, 08:24 AM
bigjacksauto's Avatar
is there a particular reason you are asking?
Another words if you are looking for one like that.
I believe the 06-probably around 2010 would have those rims and running boards
on the lt2 model.
as far as the panels go and as far as I know other than the SS the panels are all the same in all years 06-11
bigjacksauto is offline
Old 04-19-2012, 08:36 AM
solman98's Avatar
Those rims are from a early 2LT. What year did the chrome clad start? That Imperial blue started in 2007.
solman98 is offline
Old 04-19-2012, 08:57 AM
Well let's see....
The presence of "Chicklets" means its a pre-2010 model.
The rims are Phase I-II, 2LT style
Its a 2007 or newer because as solman98 pointed out, Imperial Blue became available from the 2007 model year up.
So the best we can probably say is that its an '07-'09 model.
And to the forum nwhite!
843de is offline
Old 04-19-2012, 09:02 AM
Not always a good idea to guess based on rims. As we all know, many have changed or swapped their rims.
firemangeorge is offline
Old 04-19-2012, 09:27 AM
emill713's Avatar
Interior shots may help narrow it down as well due to some of the changes inside. Notably the window up/down buttons.
emill713 is offline
Old 04-19-2012, 09:58 AM
JoeR's Avatar
How about looking at the sticker on the door. That says the month and year of production.
If that's not possible, the year is part of the VIN, visible through the windshield.
JoeR is offline
Old 04-19-2012, 10:11 AM
2007HHRLT's Avatar
Pretty sure that is a 2007 HHR LT2 - I have the exact same HHR, Color and all. But its missing the LT badge on the right of the rear liftgate.
2007HHRLT is offline
Old 04-19-2012, 11:22 AM
Greybeard999 is offline
Quick Reply: Year of this HHR?
