GM Recall Campaigns For Information & Discussion of General Motors Recalls
Ignition Recall done, now ignition binds and won't turn.
Old 10-24-2014, 10:01 PM
  #31
1961mustang's Avatar
My wife's 2009 had the recall repair made about 3 months ago. She told me tonight that her ignition switch will not turn at times, she can wiggle the key and it will then turn. Sounds like possibly a second recall ignition switch problem.
1961mustang is offline
Old 10-25-2014, 07:21 AM
  #32
Technical Moderator
More likely the old steering wheel lock thing. Just wiggle the wheel left right a bit to release the cog, then the key should turn.
That is a normal thing since the 70's.
donbrew is offline
Old 10-26-2014, 04:07 PM
  #33
timmay5309's Avatar
When my recall was done, the key would stick into the start position, and I would have to physically turn it back to run. When I asked them about it, they said it should loosen up after a few turns. The turn signal cancel stopped working after the ignition replacement as well. Luckily, I brought it right back, and they had to replace the ignition sleeve, and did not have the cover put back on correctly which fixed the turn signal issue they caused.
timmay5309 is offline
Old 10-29-2014, 05:01 PM
  #34
rhomanski's Avatar
That happened to me too. I always unlock it with the key as well. The dealer told me mine was done. I walked up to it and unlocked it and the horn started blaring. I finally got it stopped, went home and locked it with the switch on the door and it never did it again.
rhomanski is offline
Old 11-06-2014, 11:37 PM
  #35
holly2452's Avatar
Thanks everyone for your replies. I've sent a private message to Chevrolet Customer Service and I am waiting for their reply on this before I go back to my dealer. I believe when my fob went bad, I used my key to enter my car and no alarm went off....just saying. Thanks Everyone...I love this website!!!
holly2452 is offline
Old 11-07-2014, 06:13 AM
  #36
LawDog88's Avatar
^^ If that's the case, you likely used the interior door locker to lock it up. So if that is the case, and you opended it with your key, that would be why it never set off an alarm, as SholtC suggested.
LawDog88 is offline
Old 11-07-2014, 01:56 PM
  #37
Technical Moderator
As is stated in the owners manual; if you lock with the fob and then unlock with the key the alarm will sound.
donbrew is offline
Old 12-18-2014, 08:03 PM
  #38
Coppell-HHR's Avatar
Ignition recall done-key barely turns & check engine light is on
2006 HHR (111k miles). Had ignition recall work done yesterday at 5Star Chevrolet in Carrollton, TX. Daughter went to drive the car today and couldn't get key to turn. Came home from work and jiggled key like crazy while pushing on it hard with my thumb. It can take at least 20 good tries and it will work itself to the start position. I drove it for 5 or 10 minutes and check engine light came on. I'm hoping it's related to the recall work in some way. Strange thing is no matter how hard or far you jerk the wheel right or left, the steering wheel won't lock. Going back to the dealer tomorrow morning and will provide updates later.
I also wanted to thank all the forum members for all their advice & photos on the butyl patch repair issue. I bought this 3M black adhesive ribbon caulk at a NAPA store and repaired the leak myself.
Coppell-HHR is offline
Old 12-18-2014, 08:36 PM
  #39
to the forum!
It does sound like the dealer's tech botched the recall repair procedure, you may want to bypass the service writer and go directly to the manager.
Glad to hear you found the butyl patch info you needed.
843de is offline
Old 12-19-2014, 08:16 PM
  #40
Check engine light was for a bad thermostat which explains why the temperature guage was flat and didn't move. Totally coincidental and reasonable for an eight year old car with 100k + miles. So thankful it didn't happen on the way home from a 5 hour drive last week. Dealer has two new keys ordered and I'm hopeful that this will fix it along with double checking that tech didn't install something correctly.
Quick Reply: Ignition Recall done, now ignition binds and won't turn.
