Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
Old 05-23-2014, 06:22 PM
  #471
Pjdaley's Avatar
A thousand thank yous!
Thank you, thank you, thank you for this post. Completed this project in about 30 minutes at a cost of $100. The most difficult part was removing the air cleaner housing. The pictures were especially helpful. My car has never run smoother. Thanks again!
Pjdaley is offline
Old 05-24-2014, 01:47 AM
  #472
Cool!!! Glad it worked out for you. Yeah that air cleaner removal is a bit finickey.
whopper is offline
Old 06-01-2014, 05:53 PM
  #473
csrvniner's Avatar
P0011 & p0010
Does anyone know if these components are covered under the 100,000 mile powertrain warranty? I only have 68,000 miles and have the codes & CEL intermittently on a 2009 HHR SS 2.0L manual shift.
csrvniner is offline
Old 06-01-2014, 06:03 PM
  #474
Yes, if your warranty is still valid within the 5 year period. You do realize it is a 100,000 Miles/5 year warranty?
whopper is offline
Old 06-13-2014, 01:58 PM
  #475
JCJSS's Avatar
Not sure if it is pertinent to your question but yesterday under warranty, on my (in 3 weeks to be) 6 year old 2008 HHR SS 2.0L manual with 61000, my dealer "replaced intake cam solenoid valve, cleared codes & test drove to verify repair".
JCJSS is offline
Old 06-17-2014, 04:26 PM
  #476
50%buffalo's Avatar
Whopper thank you for the detailed step by step instructions..finished the job in about 45 minutes..and believe you me I have two left hands....
I have heard from a Chevrolet mechanic that is is advisable to change the oil ASAP in your opinion is that something I should follow up with??
Thanks Again
50%buffalo is offline
Old 06-17-2014, 05:16 PM
  #477
Technical Moderator
Thanks Again
Yes, with the proper weight oil. That detail is buried in this thread.
donbrew is offline
Old 06-17-2014, 06:27 PM
  #478
x2 - you bet - get that oil changed soon. The solenoids have been known to get contaminated by dirty oil, so I remember.
whopper is offline
Old 06-17-2014, 08:36 PM
  #479
Technical Moderator
And maybe run some SeaFoam in the oil for a time to clean it out.
donbrew is offline
Old 07-23-2014, 07:59 AM
  #480
sdwcheney's Avatar
to clean out the recess area I pored some denatured alcohol in it them used the shop vac to suck it up. area looked like new. then safely removed solenoid and replaced it.
sdwcheney is offline
Quick Reply: Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
