Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
Old May 23, 2014 | 06:22 PM
  #471
Pjdaley's Avatar
A thousand thank yous!
Thank you, thank you, thank you for this post. Completed this project in about 30 minutes at a cost of $100. The most difficult part was removing the air cleaner housing. The pictures were especially helpful. My car has never run smoother. Thanks again!
Old May 24, 2014 | 01:47 AM
  #472
Cool!!! Glad it worked out for you. Yeah that air cleaner removal is a bit finickey.
Old Jun 1, 2014 | 05:53 PM
  #473
csrvniner's Avatar
P0011 & p0010
Does anyone know if these components are covered under the 100,000 mile powertrain warranty? I only have 68,000 miles and have the codes & CEL intermittently on a 2009 HHR SS 2.0L manual shift.
Old Jun 1, 2014 | 06:03 PM
  #474
Yes, if your warranty is still valid within the 5 year period. You do realize it is a 100,000 Miles/5 year warranty?
Old Jun 13, 2014 | 01:58 PM
  #475
JCJSS's Avatar
Not sure if it is pertinent to your question but yesterday under warranty, on my (in 3 weeks to be) 6 year old 2008 HHR SS 2.0L manual with 61000, my dealer "replaced intake cam solenoid valve, cleared codes & test drove to verify repair".
Old Jun 17, 2014 | 04:26 PM
  #476
50%buffalo's Avatar
Whopper thank you for the detailed step by step instructions..finished the job in about 45 minutes..and believe you me I have two left hands....
I have heard from a Chevrolet mechanic that is is advisable to change the oil ASAP in your opinion is that something I should follow up with??
Thanks Again
Old Jun 17, 2014 | 05:16 PM
  #477
Thanks Again
Yes, with the proper weight oil. That detail is buried in this thread.
Old Jun 17, 2014 | 06:27 PM
  #478
x2 - you bet - get that oil changed soon. The solenoids have been known to get contaminated by dirty oil, so I remember.
Old Jun 17, 2014 | 08:36 PM
  #479
And maybe run some SeaFoam in the oil for a time to clean it out.
Old Jul 23, 2014 | 07:59 AM
  #480
sdwcheney's Avatar
to clean out the recess area I pored some denatured alcohol in it them used the shop vac to suck it up. area looked like new. then safely removed solenoid and replaced it.
