Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
Old Oct 5, 2013 | 05:38 PM
  #371
Vegashoward's Avatar
Cam shaft actuator p0010 bank1
Thanks in advance for any help would this thread help me to fix this issue. It shows to replace the cam shaft actuator. But in the thread it doesn't say anything about "bank 1" is this the same thing? Just for more info my car when it comes to stop my car jumps. Is this associated with the problem I'm having?Well thanks again
Old Oct 5, 2013 | 06:06 PM
  #372
You can ignore the Bank 1 reference - the P0010 points to the intake side - so just replace the intake side's solenoid, and all should be good. :)
Here is an explanation on what Bank 1 means:
http://www.obd-codes.com/faq/what-is...and-bank-2.php
Being the HHR has only an in-line 4 cyl, we only have Bank 1. A v-8 has both bank 1 and 2, as does an opposed 4 like a VW Beatle, or a Subaru.
Old Oct 6, 2013 | 01:31 PM
  #373
Thank you is this problem that I am having with the car jumping when I come to a stop related to this cam shaft actuator solenoid?
Old Oct 6, 2013 | 02:06 PM
  #374
Probably not, but maybe.
Does your "check engine" light come on? If it does go to your local Autozone/Advance/O'Reilly and have the OBDII codes read.
If you don't have the CEL lit up, then you will need to go to a mechanic or supply more information.
Old Oct 6, 2013 | 03:19 PM
  #375
If you are referring to the transmission shifting hard and the P0010 code you mentioned in your prior post here - YES!
I think you need to go read the first post in this thread.
Old Oct 6, 2013 | 03:26 PM
  #376
Roger it doesn't shift hard but I will take a look at the first thread thanks again
Old Oct 6, 2013 | 03:32 PM
  #377
Well, what do you mean by the car jumping? If you mean it jerks hard when coming to a stop, or when putting it in gear, and sometimes from gear to gear while driving, then the solenoid is definitely suspect (along with the P0010 code).
Old Oct 6, 2013 | 06:17 PM
  #378
I guess yes it's from going from gear to gear as I'm slowing down to a stop. But it's very specific though when it's at a stop the rpm's go up and down causing the vehicle to feel like it's puttering not jumping sorry
Old Oct 6, 2013 | 06:53 PM
  #379
Yeah, go ahead and replace that solenoid - the part number is listed in the first post I believe. I'd recommend a genuine GM part, not an aftermarket one from a parts store.
The P0010/11/13/14 are usually accompanied by what many refer to as "hard shifting" - all part of the computer controls.
Old Oct 7, 2013 | 05:11 PM
  #380
Thanks again I appreciate sir
