Tightening Torque Values for Common Maintenance Items
Old 09-28-2015, 12:54 AM
Here is a list of commonly referenced torque values for general maintenance items.
It is by no means a comprehensive list, and should be accurate for the various HHR models,
but do double check to ensure their accuracy if something does not look quite right.
Please point out any error or suggest additions, and I will update the post here as necessary.
I keep a similar list tacked to the wall near my tool chest.
OIL CHANGE
oil cap and drain plug - 25 Nm or 18 ft/lb.
WHEEL LUG NUTS - 100 ft lbs
SPARK PLUGS - 15 lb ft or 20 N.m
FRONT BRAKES:
Caliper guide pin bolts - 25 lb ft or 34 N•m
Brake hose-to-brake caliper bolt to the brake caliper- 33 lb ft or 44 N•m
Application Specification--------------------------------------Metric-- English
Brake Caliper Bleeder Valve - Front (J41, JL9, JM4)-----11 N•m-- 97 lb in
Brake Caliper Bleeder Valve - Rear (JL9)------------------11 N•m-- 97 lb in
Brake Caliper Bracket Bolt - Front (J41, JM4)-------------115 N•m-- 85 lb ft
Brake Caliper Bracket Bolt - Front (JL9)-------------------130 N•m-- 96 lb ft
Brake Caliper Bracket Bolt - Rear (JL9)--------------------115 N•m-- 85 lb ft
Brake Caliper Guide Pin Bolt - Front (J41, JL9, JM4)-----35 N•m-- 26 lb ft
Brake Caliper Guide Pin Bolt - Rear (JL9)------------------35 N•m-- 26 lb ft
Brake Hose Fitting Bolt - Front and Rear------------------40 N•m-- 30 lb ft
- J41 Brakes, front disc/rear drum,
- JL9 Brakes, 4-wheel antilock, 4-wheel disc (ie: SS model)
- JM4 Brakes, 4-wheel antilock, front disc/rear drum
( Look on your RPO list in the glove box to determine which spec to use if not sure)
HUBS - Front:
Wheel Bearing/Hub Assembly Mounting Bolts - 85 lb ft
Wheel Drive Shaft Nut - 155 lb ft
STEERING RACK:
- steering rack mounting bolts - 81 ft/lbs
- intermediate shaft outer yoke pinch bolt - 25 ft/lbs
SUSPENSION - FRONT:
rear shock bolts - TOP: 66 lb ft, BOTTOM: 92 lb ft
Strut bearing plate nuts 15 lb ft
Front Swaybar bushing brackets : 37 lb ft
Sway bar endlink bolts: 59 lb ft
Front knuckle bolt: 89 lb ft
Lower Control Arm rear bolt: tighten to 100 N•m (74 lb ft), then tighten an additional 180 degrees.
Lower control arm to frame bolts - 55 N•m (41 lb ft).
Lower control arm balljoint pinch nut/bolt - first pass: 37 ft/lb, then loosen it 3/4 of a turn - second pass: 37 ft/lb, - then tighten it an addition 30 deg
SUSPENSION - REAR (SS model)
-----------------------------------Metric ---------------English
Bracket to Body Bolts ----------90 N.m + 45° ----66 lb ft + 45°
Brake Hose Fittings ------------19 N.m ----------14 lb ft
Bushing Through Bolts ---------90 N.m + 60° -----66 lb ft + 60°
Shock Bolt Lower -------------125 N.m ----------92 lb ft
Shock Bolt Upper --------------90 N.m -----------66 lb ft
Wheel Bearing/
Hub Assembly Mounting Nuts ---45 N.m + 30° -----33 lb ft + 30°
VALVE COVER:
Cam Cover to Cylinder Head - 10 N.m or 89 lb in
Cam Cover to Ground Cable Bolt - 10 N.m or 89 lb in
Cam Cover to Ground Cable Stud - 10 N.m or 89 lb in
CAMSHAFT:
- Camshaft Cap Bolt - 10 N.m or 89 lb in
- Camshaft Position Actuator Solenoid Valve Bolt - 10 N.m or 89 lb in
- Camshaft Position Sensor Bolt - 10 N.m or 89 lb in
- Camshaft Timing Chain Tensioner - 75 N.m or 55 lb ft
- Exhaust Camshaft Position Actuator – 89 inch pounds
- Intake Camshaft Position Actuator - 89 inch pounds
THERMOSTAT HOUSING:
Thermostat Housing to Block Bolts - 10 N.m or 89 lb in
TRANSMISSION - 5 SPEED MANUAL:
Drain Plugs 38 Nm - 28 lb ft
Front Transmission Mount Bolts 50 Nm - 37 lb ft
Front Transmission Mount Through Bolt 100 Nm - 74 lb ft
Heat Shield to Engine Block Bolt 30 Nm - 22 lb ft
TRANSMISSION - AUTOMATIC:
Transmission pan 10 N.m. 89 lb. INCH
whopper is offline
Old 09-28-2015, 07:12 AM
Thanks , how about wheel lug nuts 100 ft lbs
Oldblue is offline
Old 09-28-2015, 09:57 AM
Done - thanks OldBlue
whopper is offline
Old 09-28-2015, 04:10 PM
Very cool whopper, outstanding work!!
843de is offline
Old 09-28-2015, 08:34 PM
He was bored! No, really this is awesome! I have my phone with me all the time and not my Haynes or Chilton manuals
Oldblue is offline
Old 09-28-2015, 09:46 PM
You nailed it - I WAS bored. LOL
Actually I needed to update my shop copy with a few specs, so thought what the heck, I should throw it online in case it might just help out oldblue.
whopper is offline
Old 10-22-2016, 04:59 PM
06HHRDUDE's Avatar
Can add these?
5-Speed Manual, Fastener Tightening Specifications:
From a service manual.
06HHRDUDE is offline
Old 10-23-2016, 02:23 AM
Awesome. Big thanks, every bit helps.
whopper is offline
Old 04-21-2018, 10:29 AM
Technical Moderator
Courtesy of Mitchell OnDemand for 2.0 SS:
donbrew is offline
Old 04-21-2018, 12:33 PM
Yes!! Good add RJ and Donbrew. Two thumbs up lads.
whopper is offline
Quick Reply: Tightening Torque Values for Common Maintenance Items
