Timing chain tensioner replacement - fix engine rattle
Old 06-24-2013, 05:57 AM
solman98's Avatar
Originally Posted by prod
Yeah this is an oily job, have a rag in hand when you remove it.
I did mine during an oil change so the block was empty.
solman98 is offline
solman98's Avatar
Originally Posted by VinceP
I just replaced the tensioner on my 96K panel. Way quieter on start up. I do have a question though. There was a piece of paper in the box with the part that stated the locking mechanism had to be released once installed. It was stated here that the oil pressure from the engine would release it. Am I o.k. here with just starting it up or is there something else I need to do?
Thanks for the write up. This was way easy and if I have to do nothing else it will be awsome. The thing that took the most time was the removal and replacement of the air box.
Mine didn't come with any such instructions and looked exactly like the new one posted here.
solman98 is offline
Old 07-30-2013, 03:38 PM
sbrice54's Avatar
plunger
Okay, worst case would be the piston falling into the engine...how hard is it to get it back out? How far can it go and could you get it with a magnet through the hole?
sbrice54 is offline
Old 07-30-2013, 06:21 PM
Technical Moderator
You have to pull the timing chain cover off, which include taking the harmonic balancer off (a minor pain to get back on and needs a new bolt).
The trick to getting the old one out is basic slowly gently.
donbrew is offline
Old 07-30-2013, 08:34 PM
sbrice54's Avatar
done!! no probs!!
Done!! 10 minutes... Didn't even have to take the air box off!!!
sbrice54 is offline
Old 07-31-2013, 07:46 AM
  #26
Nice sbrice54, nice write up Prod and confirmation of the ease to r&r the tensioner solman98 and donbrew
Oldblue is offline
Old 07-31-2013, 03:06 PM
  #27
jczboy's Avatar
This is what happens when you let it go to long. The fixed tensioner came out in about 10 pieces.
jczboy is offline
Old 07-31-2013, 04:02 PM
  #28
alexrckid's Avatar
question..........at he tipof the tensioner is a slot....how do you get that slot to orientate itself over the bracket inside he engine..?? does it self align, somehow...???
alexrckid is offline
Old 07-31-2013, 06:01 PM
  #29
prod's Avatar
Ya, just trust it to align with the chain as you turn it in.
prod is offline
Old 07-31-2013, 06:03 PM
  #30
jczboy's Avatar
I believe the slot will engage and rotate as you screw it in, When I did my friends it went right in.
jczboy is offline
Quick Reply: Timing chain tensioner replacement - fix engine rattle
