Turn signal canceling
Old 02-07-2016, 08:18 PM
lasater's Avatar
Turn signals stopped cancelling so I replaced the lever/turn signal switch with a new OEM unit. No change. Still won't cancel. Any ideas???
lasater is offline
Old 02-07-2016, 09:03 PM
Ok. Haven't had one out in a HHR but shouldn't there be a lobe, knob or whatever that triggers the cancellation ?
Something fixed to the column that turns with the column ?
Come on Cliff. I figured with your skills you would be able to figure this one out by yourself.
firemangeorge is online now
Old 02-07-2016, 09:21 PM
lasater's Avatar
Yeah, I just didn't want to tear into it again. I was hoping there was an old Indian trick or an ancient Chinese secret to it. Honestly, I'm so busy with the V8 build I really don't want to spend any time doing anything past an oil change on my daily driver. I guess I'll have to pull it back apart and strip the colum down to find out what activates the turn signal cancellation.
lasater is offline
Old 02-07-2016, 09:43 PM
Cliff. Try this link, post #23. It may help. https://www.chevyhhr.net/forums/how-...s-37992/page3/
Old 02-07-2016, 10:59 PM
Dang - ya beat me to it FMG. :)
whopper is offline
Old 02-08-2016, 08:36 AM
You shouldn't need to tear into the column. Jut remove the switch and make sure the cancel tab is engaged
Oldblue is offline
Old 02-08-2016, 09:00 AM
Technical Moderator
I have a feeling that if it's that black plastic bit on the column that broke it means a new steering column.
donbrew is offline
Sno White
"How To" Tutorial Library
94
09-14-2019 03:00 PM
FURIOUS10
06-10-2015 01:06 PM
eagle914
01-15-2013 11:10 AM
ummlee
05-15-2009 07:33 AM
Quick Reply: Turn signal canceling
