Front Brake Pads & Rotors & New Front Tires
Old 06-05-2013, 09:34 PM
Charvel1975's Avatar
Question Front Brake Pads & Rotors & New Front Tires
Hello, I visited VanDevere Chevrolet in Akron, OH where I purchased my 2010 HHR LS for an oil change & cabin filter change back on 5/4/13 and they recommended replacing the front brake pads and rotors and said the estimate would be about $300 for the AC Delco rotors & pads including labor. They said the labor if I went and got my own rotors & pads would be $119.
I saw this on autoanything.com, it's the Power Stop Brake Kit:
http://www.autoanything.com/brakes/6...aspx#community
Have any of you ever used this brake pad & rotor kit and any feedback? I know I don't have an super high performance HHR or anything but it looks like on their site they want $171.90 /kit and Free Shipping so if I got the kit and had them put them on it would be about close to the same estimate they gave me that I mentioned in the beginning. Also they recommended replacing the 2 front tires, they said the back ones looked ok. I thought I saw a thread on here about the General AltiMAX HP Passenger Performance Tire 215/55R16 http://www.walmart.com/ip/General-Al...00000027727770 saying it was a pretty good affordable all season performance tire? Any help on this would be greatly appreciated!
Charvel1975 is offline
Old 06-06-2013, 12:39 AM
You can get Premium quality rotors & Pads @ Napa auto parts, for much less.
Install is so simple. Plenty of "how to's" here, using the search function.
sleeper is offline
Old 06-06-2013, 11:20 AM
the brakes are down to $169.05 on sale on the site you posted, just 45 minutes to an hour to change the pads and rotors, they are very easy to change out, as for the tires, that depends on your driving and ride preference and wallet
Oldblue is offline
Old 06-06-2013, 11:40 AM
bigjacksauto's Avatar
I remember another member wrote up something stating to stay away from drilled rotors.
But the Feedback on these seem to be very good.
bigjacksauto is offline
Old 06-06-2013, 11:44 AM
I have the slotted rotors, only issue is , nobody with a brake lathe will turn them, as the slots mess up the cutter tool in the lathe, apparently
Oldblue is offline
Old 06-06-2013, 12:43 PM
IgottaWoody's Avatar
probably have to take them to a machine shop and have them take a stone to it like when they redo a flywheel...
IgottaWoody is offline
Old 06-06-2013, 01:21 PM
alexrckid's Avatar
awhile back had to do front brakes. went to advance auto parts. picked up wearever rotors and pads....cheap. been on for at least 1.5 years....no problems. and, the job was super simple........just make sure to use the proper brake lube in the right spots..........
alexrckid is offline
Old 06-18-2013, 11:51 PM
mikep01's Avatar
rockauto has them for 135.00
mikep01 is offline
Old 06-23-2013, 01:51 PM
Wound up having the dealer put new GM front rotors & pads on, had a $25 off service coupon which pretty much covered the taxes, came out to about $320
Old 06-23-2013, 04:38 PM
Technical Moderator
I routinely put pads on my HHR, like twice a year on account of at least 70,000 miles a year. Go to Ebay ceramic pads for around $25.00, rotors around $20 each. For a daily driver they are just great. KEEP YOUR REAR BRAKES ADJUSTED!!!!!!!
donbrew is offline
rainmanva
Maintenance and Upkeep
08-13-2013 07:39 AM
blacky
07-11-2013 06:02 PM
JAMIROBri
21
11-28-2012 06:46 PM
tjm
0
09-08-2009 02:45 PM
Quick Reply: Front Brake Pads & Rotors & New Front Tires
