5W20 oil?
5W20 oil?
Ok so ipicked up my hhr used a few weeks ago and just noticed the oil change sticker said it was changed about 1000 miles ago and 5w20 was put in it i checked the owners manual it calls for 5w30 normally i wouldnt sweat it but..... looking for some feed back
It could be a typo error or was the car from the cold country. What does the DIC read? I don't believe 5-20w oil will hurt anything. If you are uncomfortable, you can always get the oil changes again for $30 or so.
If your driving is short trips, then keep the 0W20. If your winter driving is normal, that is you drive for more than 15 min at a time, put 5W30 in it at the next oil change.
5W20 is not the correct oil and, over the long haul, may cause problems.
